If you really like and very well know instrument flying, then go ahead and do the II as the initial.
Straight-forward right out of the PTS.
You are aware that the double-eye without a single-or multi eye rating won't be able to instruct in an aircraft, right?
Straight forward, but nearly worthless on its own. You will be limited to ground school and simulator/FTD training. No airplanes.
I did my CFII as the initial. it really doesn't matter what you do first. yes CFII is useless on its own, but the thing is, is that most places won't hire you with just a CFI either. everone wants CFI and CFII at least.
...must hold an instrument rating on his or her pilot certificate
...and flight instructor certificate that is appropriate to the category and class of aircraft used for the training provided.
Where does it say that in the FARs? Under privileges 61.193 it says you can instruct to train for an instrument rating? Is it in the CFII PTS?
