Gentle reminder for the OP, it's not just tracks anymore. It's tracks, rollers, and housings. Housings are easy and quick to change but each one can run $800 unless you go with Robair's parts.seat tracks.
I have a good fuel bladder nightmare story that were just wrapping up now.Seat rails, mag switch, fuel bladders n placards, that one isn't actually recurring but the placards disappear so often...
Sent from my XT1254 using Tapatalk
It won't apply to you, we have a Cessna that had had the bladders replaced with hard fiberglass tanks. They started to leak so we pulled them out and replaced with stock bladders. First step of the process was remove both wings because the hard tanks had to come out by drilling off the butt ribs. Then we had to rebuild the sump area which had been modified to fit the hard tank. And reinstall the snaps in the lower surface of the tank bay that had been removed. And restore the fuel sender cutout in the butt rib to its original configuration. And fab new fuel lines for the wing root because the outlet design on the hard tanks was different. I'm sure I'm missing a few more items but you get the idea.Thanks for the info...
Roger--Do you want to share now or after I get done with the pre purchase inspection?
Stc?It won't apply to you, we have a Cessna that had had the bladders replaced with hard fiberglass tanks. They started to leak so we pulled them out and replaced with stock bladders. First step of the process was remove both wings because the hard tanks had to come out by drilling off the butt ribs. Then we had to rebuild the sump area which had been modified to fit the hard tank. And reinstall the snaps in the lower surface of the tank bay that had been removed. And restore the fuel sender cutout in the butt rib to its original configuration. And fab new fuel lines for the wing root because the outlet design on the hard tanks was different. I'm sure I'm missing a few more items but you get the idea.
Yeah, monarch air. Sounds like a good idea but the reality isn't as good. I'd rather battle a bladder than have to pull a wing to diagnose and fix a fuel tank leak. I have to say, no one did fuel tanks better than Piper on ther Cherokee family.Stc?
That I would certainly agree with, though the metal tanks on the 150 and 172 series are pretty easy to deal with.Yeah, monarch air. Sounds like a good idea but the reality isn't as good. I'd rather battle a bladder than have to pull a wing to diagnose and fix a fuel tank leak. I have to say, no one did fuel tanks better than Piper on ther Cherokee family.
Here's a novel idea. Instead of using "some dudes on a website" as your reference there is an organization called the FAA. They have this thingy called a web page where you can check out ADs on all sorts of equipment- airplanes, props, engines... You name it.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/MainFrame?OpenFrameSet
Wasn't the whole point of this thread to help with parsing through the FAA website? In the words of the OP: "It's taking awhile to read each one."
Cmon Sam, this guy is researching buying an airplane and just wanted a little help sifting through the chaff of 40+ years of ADs to learn the big ones to watch for. Nothing wrong with that and even as a somewhat experienced IA I would do the same thing on a type that I wasn't familiar with.Here's a novel idea. Instead of using "some dudes on a website" as your reference there is an organization called the FAA. They have this thingy called a web page where you can check out ADs on all sorts of equipment- airplanes, props, engines... You name it.
Heck, the airframe is not even the only item that may have a recurring AD. Engines, propellers, STC items may, as well.\
This was the entire point of the thread in the first place. The aircraft was 75 NM away and the AD's needed complied with prior to ferrying it back for the annual. I could look over the airframe and engine AD's on the FAA website but didn't want to take another pilot over with the intentions of flying it back only to find there was some recurring AD on an accessory I was unaware of.
