Chris_Ford said:One, I don't like how you hit *enter* *enter* *enter* *enter* then dot, I like white space between the post and the signature line. If I don't put something (such as a period) after the *enter* *enter* etc (sometimes I get carried away and do it five times) the vBulletin software just tosses the *enter*s out, and shoves the signature line right under the bottom of the text. Would it be more acceptable if I used a different character, or a smiley of some sort? I chose the period because I think it's the least intrusive character on the keyboard. so I always have to edit when I respond to you, You could leave them in there if the delete task is too much work.
and I also don't like how long-winded your responses are, Oops. You got me there - - nobody likes a windbag, huh? I'll try to work on that. and that you quote one line, write a paragraph, quote another, write another paragraph. I believe that's a good way of communicationg exactly what I'm responding to. Since there is often a good deal of time between posts, and most people don't follow them in a real-time fashion anyway, there is often confusion introduced when a remark is disassociated with it's related response. By placing the original thought immediately above the response, the reader doesn't have to wonder, "What is he talking about?" The "what I'm talking about" is conveniently quoted immediately above what I'm saying about it. Of course, there is this other technique that I've seen where the author just types directly in the quote, but uses a different color to distinguish his thoughts from those of the original author. Frankly, THAT method annoys me, so I avoid it. However, I thought I'd try it once to see how you like it. What do you think? If you like this technique better, I'll consider it. It's easier to do than the multiple-quote. I only go to the effort of multiple quote references because I think they're easier to follow. If they're not, I'll spare the effort in the future.
The key to being a good writer is to be succinctThat certainly is a key. I'm in favor of whatever is required to clearly communicate. If that requires a few more words, I think that takes precedence.
/I know you didn't ask me, but I'm just gripingI'm used to griping.
Oops... I forgot... If I don't add something below the quote, vBulletin considers the length of the post to be zero, and five characters is the minimum.
If I use this method, would you be amenable to me using five periods?
