Brightwork
MikeOH58
After each flight I try and rub the leading edges down with hot water and sometimes a mix of alcohol. Then a thorough drying.
Cass
You'll have that
Plexus plastic cleaner works good on the hawkers. Spray can, gets bugs out of the TKS panels, and makes 'er shine real nice like. Permatex makes a plastic cleaner that does good as well but it's a bit more time consuming (wipe on, dry, wipe off, etc.), so I just use that stuff on the screens to keep out the scratches.
n57flyguy
Any cleaning product recommendation to keep brightwork polished? (without using a buffer)
For day-to-day take the bugs off stuff, I would use any acrylic cleaner such as Plexus or Prist. My favorite by far is "MS" Cleaner. Use with a microfiber, or DuPont Sonarta rags.
For an actual polish, even by hand, Nuvite "S" cut. Don't expect a short day, either....if you are going to do it, do it right.
