Brake overheat
Fmrcmrplt
A few weeks ago this happened to me.
Desending into LGA on the Korry 3 arrival. We had taken off 1.5hrs earlier. Everything was proceeding normally on the arrival when we get a "Brake TEMP" Warning msg at F270 on the arrival. A quick look at the BTMS (brake temp senor readouts) show the outer right brake is 20 (the max it can be) and the right inner brake is reading zero. Also, the overheat wheel well protection hasn't gone off (you suspect it is a sensor issue).
Here is the question: Do you preform the memory item (speed below 220 and drop the great at FL270) and then slow to 200kts at to put the gear up or do you do nothing unless the Wheel well overheat goes off?
If you're already on the arrival I would ask for a descent, to maybe 15,000 or below, to increase my power available and decrease the low speed stall speed. Then I would perform the memory items, ask for priority to the airport and the trucks. I'm fairly certain that the brake has not overheated, as the tire is not spinning, and as a result not enough friction to create the heat. However, by going down and doing the memory items i have covered my behind, while not creating a greater emergency at altitude by getting myself into a self induced stall.
Just curious why you would ask for priority to the airport for this? Are you thinking you would be low on fuel (by descending early and putting the gear down)?
That's what we ended up doing.
And it was the sensor, wasn't it?
It's a complete pain in the butt when this kind of crap happens, because you know what the problem really is. I've seen this happen on the ground in the EMB-145, though with that aircraft, we have no wheel well sensor, no memory items, and the it only gives the EICAS message when you depress the brake.
The funny thing is that the solution is for MX to MEL the temp system and you go about your day without it, while having to look at charts to determine how quick you can do a turn.
Could be a burst tire, but that would be rare if it just randomly occurred inflight. If there are any signs of damage (fuel/hydraulic leaks, etc.), it's best to get priority handling.
"Hey Brand X 3155, you know your right main gear is smoking, right?"
"...no."
*ding* BRAKE OVERHEAT
"Ohhhh."
Funny, because the only times I've seen smoke the sensors say everything is fine.
It was odd. We didn't even touch the brakes (I mean, the runway was 13,000' long at the hub) and unless we were severely dragging one on taxi-in, I still don't know how that happened.
