Boeing teases the 797
Genuinely curious, and not to prove if anyone is smarter than another, is that how it reads in limitations?
Ours is 160 ft AGL if CAT1 is displayed on FMA. This is usually very rare. Something would have to be wrong almost. Like when you take off the AP, CATIII would then become CAT1 on the FMA. So our limitation says 160AGL to disconnect AP if the FMA was showing CAT 1.
If CATII or CATIII are displayed on the FMA, our limitations allow the AP on all the way to 80 ft AGL. Almost always, with most approaches and equipment functioning normal, the FMA will display CATII, CATIII Single, or CATIII Dual.
So for all practical purposes, as long as we're on an ILS, technically the AP can be kept on til 80 AGL.
It doesn't matter we're doing a CAT 1 approach, it's what's on the FMA that is the basis for our limitation.
The takeoff limitation thing for us is 100 ft AGL, but with a notation that the AP cannot be engaged in the the first 5 seconds after liftoff due to an internal FMGS thing. I've never thrown the AP on at 100 feet during takeoff, but I would imagine 5 seconds happens after 100AGL. Especially if the 5 seconds starts after weight on wheel signal shows plane is airborne. That's why I hinted that in reality, maybe the limitation really is 5 seconds.
Again, our limitations could be different. But that's how ours read.
Better forget all that when you're flying your 737 outta LAX!
Don't make me.....
:D
Ours specifically states, 160' agl when CAT 2/CAT 3 not displayed on the FMA. It says nothing about 80'.
Ahh ok. Makes sense. We had the 80 ft limitation in 2012. Then removed about 2014. Then added back this year.
AP off by 80 ft AGL when CATII or CATIII displayed. (which is usually almost always the case)
I've had plenty of times the throttles moved but the engines said LOL. It's just a intention and not a result.
Man, I am full-on Francophile now, this is hilarious!
Help me de-Embraer @jtrain609.
Ain't no way, son. I'll "bid down" as soon as the opportunity presents itself.
So help a Boeing/McD pilot out. Y'all are saying that the AP has to be off by 80 feet on a CATII/III? How do you auto land?
Nope, you have it backwards. If CAT II or CAT III is NOT displayed(on the FMA), you can't autoland.
So what we're saying, a plane-jane (see what I did there..) cat I approach the autopilot has to be off at 80/160' agl.
There is a host of other restrictions which I'm too lazy to look up as well.
So you cannot autoland from a CATI? Hell, even the MD88 can do that.
No, real CAT II and CAT III are all autolands.
If you're manually landing, the AP has to be off by 80 AGL if CATII/CATIII is displayed on FMA. Or 160AGL is CAT 1 is displayed on FMA.
Confusion is what's on FMA versus real approach you're doing. As long as all equipment working, you should always get a CATIII on FMA for an ILS. That means AP can stay on til 80AGL on a visual approach, backed up ILS.
If you're doing a real CATII or CATIII, that's a regular autoland.
The confusion is what the FMA shows is your limitation. As long as everything is working, on an ILS approach once you arm, it'll get you CATIII Single. Arm 2nd autopilot, you get CATIII Dual on FMA. That's our standard op for all ILS.
Now..... "downgrade" situations. You take the authotrust OFF. CATIII on FMA will degrade to CATII. That's your new limitation. Still can do autoland, but need higher RVR per CATII requirements versus CATIII.
If the AP fails, both of them, in the FMA, CATIII switches to CATI. This FMA column simply shows approach *capability* , NOT what you are actually doing. Obviously you can't autoland with no AP.
SO....... for standard ops, in an ILS, you arm approach mode and arm 2nd autopilot. and capture LOC and GS. Your FMA shows capability as CATIII-Dual. Now since you're visual, you take autopilot off, the plane senses a degradation of systems, mainly, no AP. Since both AP were on, and simultaneously both were turned off with pilot pushing the red disconnect button, FMA initially shows "CATIII-Single" as it registers one AP off. A second later it senses both AP are off, and FMA displays "CATI". That's just approach capability on FMA. Since both AP are off, you are approach limited capability to non-autoland.
You can autoland to a CATI. But on that approach, your *capability* on the FMA will still show CATIII.
The FMA is showing your capability to do the highest level approach. As things fail, it automatically shows next degradation level.
So engine out, boom, instant CATIII-Sigle mode. That's Fail-Passive. The Fail-Active is CATIII-Dual, which is best case scenario and a failure of one shouldn't degrade your autoland ability below 400 feet.
If you're flying along and arm approach to capture ILS, and only CAT1 shows on FMA, you've had a failure or degradation somewhere. Most likely a systems issue or some fault which you're aware of. But with capability showing as CATI on FMA, you must take off the AP by 160AGL.
No degradations, FMA will show CATIII on FMA, and you must take AP off by 80AGL if non-autoland.
I hope that clarifies it
