TFaudree_ERAU
Mashin' dem buttons
I'd certainly look hard at anything but a king air.
PC-12, TBM...
Disagree. You can put a lot of gas through that second engine with the money you save by buying a King Air.
PC-12, TBM...
I only joined for the legal plan. I saw it work firsthand very well for someone, and at the current price, if I keep it up until I'm 70, will be cheaper than a few hours with a lawyer.Euh, no. Is it available for free on the interwebz? Cause I stopped sending those bastards money around about 2005, which was, coincidentally, the same year the 10,000th "WE NEED YOUR MONEY TO PROTECT GA" piece of junkmail appeared in on my doorstep.
Or he should by a turbo commander. I think they're at least as cheap as a MU-2 but don't have the SFAR. As long as it has the -10's you'll see over 300 ktas on less fuel than any king air burns, and close to what the pc-12 burns.Well, that should go double for an MU-2, then, shouldn't it? Price of acquisition is half that of even a clapped out old 90. Plus you burn about the same fuel, go MUCH faster, and look WAY cooler.
Damn, you're right. As Travis suggests, your boss should buy an MU-2. Thanks, faudree!
I do not know that. It's sitting at PAMR if you want to come up and check it out.No kidding. What model?
I'm busily complaining about the fact that Camarillo was down to freezing last night; no thanks.I do not know that. It's sitting at PAMR if you want to come up and check it out.
It's not that bad. I mean it's a DRY cold... well sometimes. You can ski!I'm busily complaining about the fact that Camarillo was down to freezing last night; no thanks.
C210, maybe turbo.Thanks for the info guys. The budget would be between $300k to $600k and the usage about 2 to 4 times a month. Would maybe buying a Baron and putting into a flying club be an option? My guess is the max passenger load would be about 4 to 5.
C210, maybe turbo.
He is pretty set on a twin
And pistons? Because unless we're talking PA31 or C402 or bigger, it's really better to have a single.He is pretty set on a twin
An older C90 maybe in the upper ranges of your price range. I don't think there is much out there that would replicate the comfort you'd get in a c90 vs a smaller piston. I miss flying the kingair.Thanks for the info guys. The budget would be between $300k to $600k and the usage about 2 to 4 times a month. Would maybe buying a Baron and putting into a flying club be an option? My guess is the max passenger load would be about 4 to 5.
They ain't sexy, but I think a Malibu/Lance/6X fits your mission at the best acquisition and operational cost.
