Cory Trevor
The way I had it explained to me by an older CFI that seems to make sense is this. Bernoulli's Principle is correct, however its applied incorrectly. It has nothing to do with the wind being forced to travel farther thus causing it to speed up because it has to catch the air molecule on the bottom. The wind hits the wing at a certain point, and at that point it builds up an area of higher pressure (Think of a snow plow that builds up a lot of snow) and behind that point is an area of lower pressure, which in this case is on the top part of the wing. This causes the pressure differential on the wing, and this also causes the wind to speed up over the wing, not the other way around.
