SpiceWeasel
Tre Kronor
Stumbled across this article on "cracked".... yes it's a "comedy" website but still... very interesting. The other busted "myths" are strange too, but I couldn't pass up putting this in front of a panel of experts. The second link, below the article, goes into a lot more in-depth of an explanation as to why Bernoulli's Principle is "BS".
http://www.cracked.com/article_20669_6-ridiculous-science-myths-you-learned-in-kindergarten_p2.html
http://www.allstar.fiu.edu/aero/airflylvl3.htm
#2. Why Airplanes Fly
The Myth:
The explanation goes like this: The wings of a plane are designed in such a way that they make air travel faster over the top of the wing than under the bottom. This means the pressure over the wing is less than the pressure underneath, causing lift. It's called the Bernoulli principle, and even the pimp daddy of all nerds, Einstein himself, is said to have given it his thumbs up. Cased closed. Right?
The Reality:
Sorry to decompress your flight cabin there, Einstein, but the "differing pressures" explanation of flight isn't correct. Instead, what's really happening has a much simpler explanation -- one that you also learned in school. You see, according to a guy named Isaac Newton and his third law of motion, for every action there is an equal and opposite reaction. Therefore, if you want something to go up -- like, let's say, a plane -- then what you want to do is force air to go down and back so that the "opposite reaction" propels the object up and forward.
And that's where the shape of the wing comes in. It's true that a plane's wing must have a very specific shape -- just not the one that's postulated by the Bernoulli principle. Instead, the wing is angled so that it forces the air on top to go down toward its back end (downwash), creating upward force toward the front (upwash).
David Anderson/Florida International University![]()
The wing generates lift not by magically manipulating air pressure, but by using basic Newtonian physics. While the Bernoulli principle is a real thing, it has very little to do with the reason mankind can spit in God's eye from his hurtling metal tubes. And nobody is quite sure why your school's science textbooks, television, and, most alarmingly of all, goddamn pilot manuals have the wrong explanation for flight. But they don't need to know why the plane flies to fly it ... r-right?
