BrewMaster
SUCKS Equals VACUUM
Wouldn't it be easier to listen to a couple CFI's then try to get us to tell you what you want to hear....especially since we know everything
SUCKS Equals VACUUM
an area which the air can not get to which means it is a vacuum.
SUCKS Equals VACUUM
What physical barrier ensures the vacuum of outer space?
No, that's not a vacuum either. If it were, lift would increase enormously. Moreover, that would eliminate the positive pressure gradient that produces the separation in the first place.
For pure concept, they are right and I don't see any reason why you can't associate that suction to pulling up on a wing.
Just because we use a term that doesn't fit the scientific definition doesn't mean it can't be used.
right there is the key. It is not a vaccuum and should be taught as such.As long as they know lift happens because of a difference of pressure
ORLY?other associations can't hurt unless they cause some form of negative transfer of learning, which I don't see any in this case.
*Flame shield on*
Negative ghostrider.A vacuum is not a force but a simple place of nothingness!
private pilot applicant exchanged the definitions for Angle of Attack and Angle of Incidence, what would the DPE think?
Some of the best vacuums meatbags have been able to produce have been done with a u-haul on the shuttle.
http://en.wikipedia.org/wiki/Wake_Shield_Facility
(Oh wait! I just contradicted my interpretation of a vacuum! Well, they don't call it a vacuum.)
Pressure is a Newtonian effect....it's the momentum transfer of molecules hitting something.
But, again, it's meaningless to say the high pressure on the bottom is the "driving force" for lift. Did you know that at low AoA, the pressure is negative on BOTH sides of the airfoil? Which then is the true source of lift?
I'm lost. I've never heard or read about Bernouli and Low/High Pressure being associated with Carburetors. Could someone flesh it out some more for me?
SUCKS = Pressure Differential (and the cowboys)
You're joking, I hope? Lift is produced by a small pressure differences around the airfoil, less than an inch of mercury. Suddenly you have a vacuum and you have almost 30 inches of pressure differential. All the surrounding air would be applying a tremendous force attempting to fill the vacuum. Doesn't happen.
Regardless, the area behind the separated flow is filled with air from the bottom of the airfoil that flows around the trailing edge to fill it.
at the separation point I believe there is a minute vacuum just above the surface.
Haven't you heard the phrase "nature abhors a vacuum"? A gas will rush to fill an area of lower pressure and a vacuum is the lowest pressure possible. If you get between the air and the vacuum, the force is net difference between the pressure of the gas on one side and the gas on the other side. Since the vacuum offers no pressure at all, the force is at a maximum.The tremendous force attempting to fill the vacuum (which is a force as you say) is applied to what and in what direction?
News to me.![]()
