Base seniority, commuting and communists
True dat. It isn't a huge issue at this point, but it'd be nice. I think what threw me over the edge was that there have been two of us hanging in the crashpad (I'm in the apartments the blocked inn) and the next thing I knew there were 5 guys crammed in here.
I'd much rather bid long call reserve and be able to cherry pick things out of open time than fend for scraps with the other 45 guys in the short call buckets at this point, and I figure the worst thing that happens is if it blows I can hopefully move back to Newark in the next perm bid that's going to come up in March if I can't hold LAX/ONT/IAH.
Yeah, go to CLE. Just b/c the numbers say that you might not get the relief line doesn't mean you won't. There might be someone senior to you that would rather have long call reserve b/c they live in CLE. Worst case scenario, you're probably only a month or so away from the relief line anyway.
Your assumption is predicated on movement, which requires hiring, which is not something my company is doing.
Hey John, I'd rent you a room in my house but I'd have to check with the wife first. 35 min drive.
I can't believe there are so many guys trying to get back out west. Your company may not be hiring, but you're still going to have upward movement due to attrition. It will work out.
I can't really suggest which would be better, because I was based in CLE and EWR as an FO and it was a wash which base was better. EWR was more fun, CLE was a closer commute. There was a bunch of pro's and con's.
I will offer this advice: Get the heck out of the Blocked Inn! No wonder you are miserable! You are spending nearly $300 a month for a crappy crashpad jammed full of crews! Find a small crashpad in Ironbound. I was in Elizabeth for a month and was losing my mind. Then I found a crashpad that was $150 a month and I had my own bed. Only 10 guys in the pad, but there were probably 10 crashpads on our block. Dunkin Donuts and a CVS within walking distance, and a bar down the street that was very "pilot friendly."
I think the quality of your crashpad and how much you can make it "home" does a lot for your situation.
Hmmm... I actually had a good experience at Blocked Inn... although I was in the main house and I was in the first room on the right at the top of the stairs. Only 6 in it and I never had more than two guys in the room at any given time so it wasn't so bad.
But hell... if you can find one cheaper that has everything you need like Chicaga says... then go for it.
Bob
You gotta look at the people ABOVE you in seniority. I'm willing to lay wagers XJT CAs are still getting hired at majors and other places. If our guys are getting on at places like Delta, jetBlue, Spirit and AirTran, I'm sure your guys are, too. Now, if they decide not to fill those CA slots for some reason or another, that's another story all together. I know my meteoric rise to the upper echelon of the FO list wasn't due to a mass of hiring of people after me.
Did I mention we canceled our upgrade classes?
Train, relax brotha! You're convincing yourself that the Tall Fescue over at Skywest is greener than the St. Augustine/Bermuda blend at XJ.
Remember my long, drawn-out, monotone speeches about ebb and flow in the airline business?
Wait a second.. Upgrades are still taking place currently.
Over 50 in December.
The most bid cancelled only set things back by a few months but were directed at the first quarter of next year. SKYW, ASA, CMR, and XJT all cancelled upgrade or seat-locked recently.
I'm at XE man :)
I'm not convincing myself of anything, either. Emily told me I can't go to Skywest to tell you the truth, and the payoff simply isn't worth it for any number of factors.
Remember I've got a lot less emotion behind my posts than you might think. I write strongly, but I'm generally pretty chill man!
Correct. As I understand it things are at a standstill for the first quarter.
I'm at XE man :)
hey now! i said nothing of the sort. I was regurgitating your own crap back at you.
