The company I work for did some banner towing before I was here, and a few months ago I did some research about getting back into it. I know that who can train someone depends on your waiver. I believe the person that we had on our waiver that could give the signoffs did not even have a commercial rating.Anyone have the regulations of hand relating to pilot qualifications for banner/ glider/ aero tow training?
As well as if the aircraft needs to be in the restricted category?
Once there, the fed watches the pilot do 3 pickups and drops, shakes the pilots hand, gives him the waiver and says good luck in your future.
You need a waiver from your FSDO for both your pilot and your aircraft. Specific requirements can vary from FSDO to FSDO. Pilot needs to be commercial if you're towing for hire. Some FSDO's specify requirements for trainers and then give those trainers the ability to issue waivers. Other FSDO's don't care as much who conducts the training but a real live fed from the FSDO is the only one who can issue the waiver. And that requires the real live fed to take a field day out of the office, pack his fishing pole and drive out to the banner field. Once there, the fed watches the pilot do 3 pickups and drops, shakes the pilots hand, gives him the waiver and says good luck in your future. Then it off to the fishing hole for the rest of the day.
As for aircraft, no FSDO that I'm aware of automatically requires banner planes to operate in the restricted category. Some companies place their planes in the restricted category on purpose because it gives them more leeway in terms of modifications and such. But there are lots of banner planes out there that don't say restricted on the side.
Im pretty sure that for glider towing, all that is required is an endorsement from an instructor saying that you have been trained to do it. That usually includes a few simulated or actual tows and some ground.
Doesn't need to be from an instructor, mine was from a PPL.
That's required if you're going to tow gliders. It has absolutely nothing to do with towing banners though. See 61.69.Also, I've met pilots before that had some sort of an endorsment on their certificate with the lingo along the line of "Authorized for Glider/ Aero-tow operations..." What's that about, if endorsements are only in logbooks?
It doesn't take very long if you know how to teach it (just like everything else I guess). But I don't think pawnee/citabria glider towing time would make much of difference in the amount of time the training would take.Though if you have a ton of Pawnee/Citabria glider towing time, I can't imagine the banner tow training taking very long.
@CFI A&P did you ever pursue this?That's required if you're going to tow gliders. It has absolutely nothing to do with towing banners though. See 61.69.
I'm seeing Glider aero tow on people's Commercial and sometimes CFI certificates when I hunt around - it's not an obsolete rating - just appears to have been superseded by an endorsement?
Man, what a necro-post. Yeah, I have done some banner towing since. No endorsement in the logbook or on the certificate. Did some ground school with the operator, followed by a few practice pick ups and lastly demonstrated pickups and release with a FSDO rep present. Not too big of a deal. Also, you can't fail the observation, because there isn't an 8710 involved. Just keep trying until the inspector goes home or you run out of sunlight.
Since that post I learned of a friend's grandfather that had aerotow and self launch written on their certificate. I guess something like that was more common or even required back in the 40s & 50s. At one time he had a motorglider that was a self-launch with retracting propeller and also a Birdog that he used for towing his own glider and with the local club. I also remember something about him having a self launch winch system, but I don't remember the details of that.
wut?If we are talking about gliders here you must have a endorsement for the type of launch your going to do.
