I would send a PM to ATLTRACON...(Moderator in the Air Traffic Control boards)Anybody officially know what they are developing on the approach end of 27L and also the departure end of 28.
He and I don't get alongI would send a PM to ATLTRACON...(Moderator in the Air Traffic Control boards)
If you are referring to the parcel of land between 28 and 27L that is where there is a proposal to build a new terminal. Check this out: http://www.atlanta-airport.com/Default.asp?url=sublevels/airport_info/gmpage.htm Click on "Airport Construction" then "Projects Timeline".
Not a problem bro. I don't remember the construction at the approach end of 27L. Do you mean 27R? If so, that is probably the most graded piece of real estate in the state of GeorgiaRelax folks. He and I get along just fine and my internet social chi is in balance. Trust me if someone and I didn't get along, I wouldn't make it known on the interweb. Sometimes I forget to take myself seriously. It's kind of therapeutic. So. Consider yourselves "fished in". :buck:
Thanks, Joel.
PS. ATLTRACON, you're my boy!
Not a problem bro. I don't remember the construction at the approach end of 27L. Do you mean 27R? If so, that is probably the most graded piece of real estate in the state of Georgia. They extended the taxiway there I guess in preparation for the new international terminal.
I think that is just the grading process that they are doing. Lot of dirt will need to be relocated along those hillsides going along the southeastern side of the complex where Loop Rd follows the complex.
That south complex terminal though. . .now that's really going suck. I don't like hoping off of 85N to get onto 285 to then go past the employee parking lot, then to do a 180 degree turn to get onto Loop Rd, and then make a right into the Lot. Nah, I like going on 85N, get off at the Riverdale Rd exit, turn right, turn left, and turn right, and then turn left into the lot.
That new terminal is going throw a wrench in my commute.
From what I recall reading way back when, the south gate complex is supposed to be a "regional" terminal, with the intent of keeping most of that traffic operating on 10/28. Knowing the cronies that run Atlanta and Hartsfield, it still remains to be seen if they actually hold to that plan or not.I checked out the airport link you put up. The 27R construction is to accommodate more passengers and a new terminal like you said. Also, the construction to the left of the approach end of 10 looks like it will be called the 'south gate complex' in which approximately 31 gates will be added with some sort of train system to relocate the peeps to the main terminal.
There is some development going on around the 27L area near Inner Loop Rd. Only reason I know is because of the bus ride to the lot. I was just hoping it was another "loop" for the southside.
The latest plan, or so I've heard, for the Southern Terminal Complex, is to relocate the carriers with a relatively small footprint at ATL. Carriers like United, AA, Frontier, etc.From what I recall reading way back when, the south gate complex is supposed to be a "regional" terminal, with the intent of keeping most of that traffic operating on 10/28. Knowing the cronies that run Atlanta and Hartsfield, it still remains to be seen if they actually hold to that plan or not.
