To everybody talking about instructors verifying fuel...why not use the gauges in flight? Fuel checks don't have to be exclusively visual checks.
That's how I do it. One of the first checks I do after engine start is a look at the fuel quantity gauges. If they both read full, I don't worry about it. If less than full, I ask the pilot how many gallons of fuel we have. Notice I say "gallons" rather than if we simply have "enough."
I've never had a problem with this method. I can't visually double-check everything and I'm not going to try.
I've never flown a piston with fuel gauges which I felt were reliable enough to depend on.
:yeahthat: There is nothing like watching a 172 gauge bounce from full to empty every two seconds.... Which is it?!? Is it Full, or is it empty!anic:
Neither have I...at least not reliable *electric* gauges (the "float-type" gauges from vintage aircraft like my C-140, or some of the new LSAs are very accurate).
But it still gives you a pretty good idea of if the tanks are full or not. I've never flown a plane that indicates completely full as the tank runs dry.
It's full of course! You saw it overflowing on the preflight, and have calculated 2.4 gallons have been burned.![]()
Well, there are times you may have to. So I wouldn't necessarily say Never x 4.
