If you have a IFR flight Plan that takes you through restricted airspace and ATC does not alter your flight plan are you OK to proceed, even if the hours of use are in effect?
I guess I am aking if ATC has the authority to use Restricted Airspace even if the hours of operation are in effect?
Is the Restricted Airspace Hot only when it is being used? or the entire time the hours are stated on the chart?
Thanks
Thanks
