The Air Force's version is similar to the Navy's (from what AMG posted), but it's even a little different than that.
Do I need an alternate?
WWW.RUG
If my destination has:
W. Weather- less than 3000 and 3 mi vis at the ETA +/- 1 hour, (or 3000 and 2 miles above the lowest suitable approaches minimum requirement, whichever is higher)
W. Winds- out of limits ETA +/- 1 hour (training command only)
W. Weather - no weather reporting capability
R. Radar is required to fly the approach (either it's a GCA approach like a PAR/ASR, or RADAR is required to identify a point on the approach, etc.,)
U. Unmonitored NAVAID.
G. GPS is the only available approach.
If any of the above is true of my destination, then I must file an alternate. At my alternate, I also have a
WWW.RUG set of rules to follow:
W. Weather- 1000 and 2 miles vis, or approach mins. +500 feet and approach mins +1 mi. vis, whichever is higher. (ETA +/- 1 Hr)
W. Winds within limits (ETA +/- 1hr, training command only)
W. Weather reporting capability- must have it... unless I can get from my destination to a point where I can continue VFR to the alternate.
R. Radar required - can't be... unless I can get to a point where I can continue VFR to the alternate.
U. Unmonitored Navaid- can't be... unless I can get to a point where I can continue VFR to the alternate.
G. GPS only suitable approach- can't be... unless I can get to a point where I can continue VFR to the alternate.
Heavies are also allowed to substitute an amount of fuel for holding instead of an alternate if there is no suitable alternate within 2 hours of flying time.
The way guys typically remember the weather #'s is by making them a phone number: 332-1521. The 332 applies to whether or not I need the alternate, and the 1521 applies to the weather at the alternate.
