Applying
jamin35008
Hi all,
I was just wondering if anyone knows the next time there will be a posting on usajobs.gov for the Air Traffic Control Specialist Trainee? I heard the last one was in Sep sometime? how many times do they post openings and is that the only way to apply for a street canidate?
Will it help me at all that I have my single/multi commercial w/ instrument rating and a B.S. in Aviation Science?
Thanks everyone!
EvoJoeIX
with that degree why not try for a different position? im sure you can get a higher up position for something other then ATC for the FAA...
as far as lisitings, what i did was just check the website everyday. once you apply it takes a while for them to contact you (at least for me it did). i applied in the summer and i was notified to take the test late november
CMS3185
Hi all,
Thanks everyone!
The latest opening was PUBNAT7 for off the street applicants. It closed in the middle of December. The process is a long one..about a year right now from the time you apply until you get to OKC, and there a lot of steps to take before that happens. You are looking for openings that say PUBNAT for off the street...it will look like this: AAC-AMH-08-PUBNAT5-10363. This is the only way for off the street applicants to apply.
I hear maybe another early this year but no one really knows.
The degree and flight time will help, especially if you have a solid work experience to go along with it.
I'm close to your situation: I have my flight ratings and a B.S. in Aeronautics from ERAU; If you have a solid work experience coupled with your schooling, you should be a great candidate and competitive. But, make sure to score well qualified on the AT-SAT (85 or higher). Lots of well qualified people applying right now. Some are getting in with lower, Qualified scores, but it seems like a high majority have WQ scores.
Good Luck
ATLTRACON(ret)
I don't know if I would go as far as saying that...I don't think having ratings, etc will help that much in ATC training, but having a degree and a bit of aviation knowledge can't hurt you for selection. Just my $.02
As far as the selection goes, I disagree. But, it will help in your general knowledge of what goes on on the other side of the mic, and general phraseology....
Oh wait pilots use whatever phraseology they want and I will get written up and possibly decertified if I don't go exactly by the book:panic::sarcasm:
CMS3185
Nice, LOL. That is true. Some pilots out there are horrible when it comes to talking on the radio.
jamin35008
I do agree that some are really bad on the mic and talk way to much or cant understand them. Thanks for the info though. I was just wondering.
dli1314
A bachelors degree will only get you as high as an F band position within the organization unless you have at least a year of prior work experience at or above a position higher than that(F band).
For Example:
You cannot apply on a G band position unless you have a Masters degree or 1 year of prior work experience at or above the F band level.
You cannot apply on a H band position unless you have 1 year of prior work experience at or above the G band level.
etc etc etc...
