There is no way as a professional flight instructor that I would allow a student exceed the limitations of the aircraft.
Are you reading what I'm writing, or just hitting reply and firing away immediately after seeing my name?
I said FACTORS OTHER THAN PILOT INPUTS. Wind shear. Convective activity. Clear air turbulence. Tip vorticies. It's got nothing to do with what you'd "allow" your student to do.
While we're talking about it, though, there are instances where you might find yourself outside normal pitch and bank limits because of pilot inputs. What about an aggressive and abrupt control input to avoid a midair?
This MUST be the case; otherwise the vertical forces wouldn't be equal to weight and the aircraft would be falling like a rock.
Yes, and that's exactly what I'm talking about. We operate in a 3 dimensional environment. Falling like a rock happens...and when it does, I can be in 60* of bank without your load factor of 2. Not everything is based on a level turn. Despite your accusation, I wasn't inventing some spurious one-off situations to cover up some mistake I made. You made a black-and-white statement, and I provided a counter to it. More than one, actually.
Seriously, anyone with a Commercial pilot's certificate should have experienced this first-hand while doing steep spirals.
You guys are ALL totally missing the mark.
Have you ever heard of unusual attitudes? Ever heard of upset training? Airplanes CAN and DO get themselves into unusual attitudes even WITH the most attentive and experienced pilots on board. There are MANY factors
outside of pilot inputs that can get you there, regardless of if it's wind shear, convective weather, tip vorticies, what have you.
What I'm talking about is that there are a lot of civilian pilots who are VERY uncomfortable outside of the comfortable limits of straight and level, and their lack of knowledge about aerobatics directly contributes to it. I think this is a complete foul that we have so many pilots who feel uncomfortable, to the point of being outright scared, at operating outside the "warm, chewy center" of the aircraft flight envelope. I've experienced this personally with a number of civilian pilots I've flown with in perfectly aerobatically-capable aircraft (with the proper equipment, too).
Nowhere am I advocating WILLFULLY going out and exceeding the CFR pitch and bank limits without chutes or exceeding the load limits of aircraft. Of course this training should be conducted in the proper airplanes, in the proper airspace, with the proper equipment (just like I've all ready posted, but you guys in your fervor to prove me 'wrong' seem to have missed reading).
What I AM advocating is that we SHOULD use those proper airplanes, that proper equipment, and that proper airspace on EVERY pilot -- if not at the Private level (that would be my first choice), then at the Commercial or CFI level -- to go explore advanced aircraft handling and learn basic acro. Is it a paradigm shift from the current thought process? Yes, of course it is. Would it require different aircraft and different equipment? Yep. Would it benefit the pilots that are trained that way? Hugely.
If Machado's article is intended to get pilots to re-think how we "make" new pilots, I'm simply identifying what I believe to be a weakness in how we currently train, and advocating a change I'd like to see that would produce a better overall aviator.
