R
Roger, Roger
Guest
A JPI EDM 930? I'm working on an install of one at work and it looks pretty friggin' sweet.
Does it generally work pretty good? I'm paranoid that we're going to boot it up the first time and have something wrong and spend 2 days troubleshooting.My boss has one on his 210. As far as I know, he really likes it.
Also, what EFIS is that that he has in there? The plane I'm working on has the G600, even more friggin' sweet...
:yeahthat:That looks like an Aspen piece.
It does everything. Oil temp, oil pressure, fuel quantity, flow, and pressure, 6 point EGT and CHT, communicates with G530 for fuel remaining at waypoint, and it's incredibly shiny.Are there more options to it? Other than rpm and manifold I don't see anything it is showing that a JPI 711 can't do for a fraction of the dash space and price.
Looks cool though.
Not a fan of the Aspen, we had one in a 172, it is not easy to read from the right seat. Glare gets to be as bad as that picture and it is worthless. Pretty lame to have a expensive toy like that but glare is so bad you have to get your heading off the mag compass.
Roger said:You've got that right, and huge! :drool:
182RG.As far as I know, it's he's had no trouble with it. In fact, he's always in awe about how accurate the fuel gauges are on it.
The PFD is the Aspen EFD 1000. That on the other hand I know he's had some trouble with, and had to send it back to get re-calibrated. He's said if he did it again he would go with a G500 instead of the Aspen.
What are you putting your avionics into?
I like the Aspen, glare isn't nearly that bad from the left seat![]()
The 'ball' is part of the attitude indicator and not obvious to someone who has never used the unit before, once you establish how it works it is sloppy at best, it takes far to long to boot up. You will confuse the ball for a bar that comes out and tells you you are uncoordinated when you first start out. Blah blah blah, the aspen is a user unfriendly POS.
The only place a aspen would truely shine is when you are in the left seat, VFR and looking out the window.
Is the JPI 711 approved to replace all the primary instrumentation? I would imagine not, if you have to cycle to see everything. With this setup there does not need to be a single analog engine gauge on the panel. Combined with the G500, it's almost as good as a G1000 system.JPI 711 does all of that except the shiny part. Still, it would be nice to not cycle to get your information. I wonder what the price difference is though. If you get a chance plug in and pull the information off of it for your entire flight, you will learn quite a bit about your flying style and where you can improve by looking at the charts. Interesting stuff, most any A&P can do this for you. Could also be used to tattle on you if you push the plane to hard.
