Ameri-King ELTs
Roger Roger
I am le tired
First off, this may be more of a MX Hangar post but I figured there's enough aircraft owners here it might do some good out in the more trafficked section of the forum. I got an Alaska Air Carriers blast mail today that the FAA has revoked approval on any Ameri-King ELTs built after 12/28, and are considering doing so for all of them. Actually, the letter says everything built by Ameri-King but their ELTs are the only things I've ever run across. They built the least expensive 406 unit on the market, and were IIRC the only remaining maker of 121.5-only units. If any of you are unfortunate enough to still have their garbage (we do in a couple planes) be ready to yank it out in the near future.
*edit* linky to the FAA notification.
https://www.faa.gov/aircraft/safety/programs/sups/upn/media/2016/UPN_2016-2013NM460018.pdf
Thanks for the heads up!
I'd think anything built after 12/28/2015 could be returned. No?
What business wouldn't take it back within 90 days of purchase?
I don't know. One would hope so but depending on how hard the Feds are hounding them they might just tap out.
I've had 4 aircraft crash in my airspace while I was working, 2 C182's, a BE36, and an F22. The only time ELT's have gone off have been from aircraft sitting on the ramp.
I'm assuming they would have been purchased though a store like Aircraft Spruce. Pretty sure Spruce would stand behind a product less than 90 days old even if the manufacture didn't.
True. Or the chute repacking shop.
In my experience the first sign that someone ejected was the PLT going off. It was proceeded by; I think I'm going to get wet but I didn't put two and two together until I heard the PLT.
What a perfect excuse to head to the hangar. It's 35* and climbing, plus a gorgeous day.
Pictures to follow.
Here in California we're heading down to 70* tomorrow. I might bring a coat.
I have personal experience with this, I think, it wouldn't have changed anything in that case, but interesting to know.
Sent from my XT1254 using Tapatalk
ELTs are a little odd to me. On the one hand they have to work when needed, but on the other the best ELT in the world won't help you get found when the crash distorts the airframe enough to pop the coax cable that connects the ELT to the antenna so what does it really do anyway.
Best thing you can do is leave a long service loop and have the antenna as far toward the tail as possible.
I guess if you hit that hard there's nobody to rescue anyway :/
I say this, but actually in one of the recent plane crashes around here the 406 beacon was probably instrumental in the survival of one of the pax.
