The center of pressure (CP) on a wing is sort of like the center of gravity in that it is the center or concentration of forces. If one could attach a string at the center of gravity and suspend an airplane it would balance. If one attached a string at the station location where the center of pressure exists for a given flight condition (we know CP changes during flight) and an aircraft where suspended by this string the airplane would nose over due to the CG being ahead of the CP. Now visualizing the upward force as this string suspending the aircraft at its CP and the CG (ahead of the CP) as a string pulling down, one can see that the larger the distance (arm/leverage) between the two values the harder the tail has to work to overcome the nose down moment. Given this visualization I find it hard to believe that an aircraft pitches about its CG and not it’s CP. Go ahead guys, where did I go wrong?
You have it right, which makes me wonder how come you're having hard time with it. One thing to keep in mind is that the gravity goes directly down through the CG and does not contribute in any way to the pitching up/down rotation. So all that you have to balance, rotation-wise, is the torque created by the wing and the horizontal stabilizer. The arm of the stabilizer is much longer than the wing, so it needs to generate much more lift. Now all this gets you no rotation. To make sure that the airplane is not accelerating up and down, the sum of all these force has to be zero. So the sum of the weight and the downward lift generated by the tail has to be the same as the amount of lift generating by the wing. Does this help?
The longitudinal axis, or roll axis does not necessarily intersect at the same point as the lateral and vertical axes. If your fuel is improperly balanced, then the axis, or longitudinal cg as it might be called, is offset and the aircraft will roll around that point...That's exactly correct - rotation happens around the CG. I think you're mixing the linear movement along any any of the axises with rotation around them. Pitching up and down is rotation along the lateral axis. What controls if and how much rotation happens is the sum of all the torques, where the torque is force x arm. Since the weight can be considered to go through the CG, its arm is 0 and thus its torque is zero as well.
Try to visualize the airplane as a bicycle wheel. No matter how much you pull it up or down by its axis, the wheel will not start turning. Now imagine that you pushed one of the spokes very close to the axis up - that will be your lift at the CP - it will make the wheel turn. If you wanted to prevent the wheel from turning, you could push on the same spoke but much further away from the axis. You'll need to push much lightly there - that's the force from the tail.
All this does not guarantee that the wheel will not fall up or down - only that it will not turn. To make it stay steady in the air you'll have to make sure that you're pushing on the spoke up hard enough to counteract for both the weight and whatever force you're using to push down at the far end of the spoke.
Right, that was a typo, you do need less force in the tail with the longer arm, not more. Thanks for catching it!BTW, not to split hairs, but because the horizontal stab is further from the CG, it actually does not have to produce more "lift" or tail down force, because its arm is longer its moments will always be greater!
Nope, the CG is a point. All rotation happens around an axis which goes through that point. In the case where your fuel is improperly balanced the longitudinal axis will move towards the heavier side together with the CG. In other words the axises of rotation are not going to be the same as the symmetry axises of the aircraft. Which is probably what you were saying too.The longitudinal axis, or roll axis does not necessarily intersect at the same point as the lateral and vertical axes. If your fuel is improperly balanced, then the axis, or longitudinal cg as it might be called, is offset and the aircraft will roll around that point...
I am trying to figure out why it would not rotate around the center of pressure--for my on personal sanity! stuff like this drives me nuts. You should have seen this post back awhile ago called "True airspeed riddle"
The CG is the fulcrum, the aircraft is the lever, and aerodynamics are the forces acting on the lever.
The CG is not supporting the system, the Center of Pressure is. therefore the CP is the fulcrum
Air is a physical object. Air has mass and if accelerated it creates a force. If a small powerful jet of air held up a balsa wood board the balsa board would rotate around that jet of air, because that jet of air would be a fulcrum.
