Murdoughnut
Well sized member
Though I notified the FAA electronically of my current address when I moved, and confirmed it shows up, my certificate still shows my address from two houses ago. Is that a problem when I go to do my next checkride?
No. They don’t issue new cert for an address change. When you pass the new checkride your new cert should reflect the current address.Though I notified the FAA electronically of my current address when I moved, and confirmed it shows up, my certificate still shows my address from two houses ago. Is that a problem when I go to do my next checkride?
I think you can opt to get a new certificate with your new address on it if you change your address on the FAA website. I think it's optional though, and not necessary to get the new cert and it may even be for a small fee. The main thing is the notification.Though I notified the FAA electronically of my current address when I moved, and confirmed it shows up, my certificate still shows my address from two houses ago. Is that a problem when I go to do my next checkride?
