A little aviation trivia for ya...
AlexSP
Two identical Cessna 172's at exactly the same altitude both experience engine failures at the same time. The pilots then maintain best glide speed, per the aircraft POH. One of the planes is heavier than the other one, so it (the heavier one) will glide farther. True or False?
Best glide speed varies by weight, whether the POH lists it or not.
If both aircraft are maintaining best glide according to their respective weights, they should go the same distance, right?
I believe that the heavier one would get to the ground first, but they would both go the same distance.
Ethan
not knowing anything about gliding, but basing this off of my rusty physics I would guess that the heavier one would go farther because it has more momentum (P=mv)
Why
The heavier one will glide the farthest, and the two planes are using the same exact speed (The best glide speed specified by the POH-The POH doesnt specify more than one speed). Can anyone explain why this is true?
Simple physics...
the weight will not affect how far it'll glide, though the heavier one will just get there faster than the lighter one.
Next!
Re: Why
Here's how I see it. The heavier aircraft will accelerate at the same speed as the lighter aircraft. However, because it weighs morethe AOA needed to keep the ideal glide speed will be different (more down pitch I think). Because of the increased downward pitch it will decend faster... but now I am killing my own argument, because if it is decending faster but traveling at the same speed it will go LESS distance then the lighter aircraft, which is not what I said to begin with. So that said, I really don't know, although I still think I have heard my first answer somewhere else before.
Ethan
Simple physics...
Next!
Really? Prove it.
Best glide is the minimum ratio of rate of sink, to forward speed. Glide ratio doesn't change based on weight. BUT...
A heavier aircraft has a higher wingloading, which means it has a higher rate of sink at the same airspeed as the lighter one. Therefore, best glide for a heavier airplane is higher than that of a lighter one. If each aircraft is flying a best glide speed according to their respective weight, they'll glide the same distance.
This is all in theory. In reality, the difference is negligable- thats why most POH's only have one number for best glide.
EatSleepFly hit the nail right on the head. Time for Question 2...
Arrange avgas, kerosene, oil, and water in the order of their weight from lightest to heaviest.
You know what's hilarious is that this thread reminds me of a party at Riddle.
A bunch of guys, one girl and we're all arguing about trivia!
Woo, lets go cruise Gurley Street and swing by Yavapai college!
Weight is constant no matter the temp. Volume changes. Hence the reason fuel is sometimes measured in lbs not gallons.
Then they all weigh the same, eh? 1lb avgas = 1lb kerosene = 1lb oil = 1lb water.
That would be true as far as I know. Maybe he's looking for specific gravity.
I'll give it a shot:
oil, water, kerosene, avgas
They weigh the same, but volume is the variable.
I think it's 6.67 lbs/gal for JET-A on average, but depending on the season, the ratio changes.
The heavier aircraft can go further.
The way I understand it is that a published best glide speed (for most GA aircraft) is based on standard conditions at max gross weight. So if a Cessna 172 lists 65 KIAS as best glide that is L/D max at max gross weight. The further you are from max gross weight the further you are from L/D max assuming you are still flying 65KIAS. Unless the heavier aircraft is over weight then it must be closer to max gross weight than the lighter one so its getting the best lift to drag ratio (L/D max) and if all else is equal it can glide further.
That seems to jibe with the more technical description of power off gliding in both "The Illustrated Guide to Aerodynamics" by HC Smith & "Aerodynamics for Naval Aviators", USN.
water is the heaviest (approximately 8.3 lbs. per gallon)
oil (don't know?)
kerosene (approximately 7 lbs. per gallon)
avgas (approximately 6 lbs. per gallon)
