A Few Logging Questions
sfgiants13
I just bought Logbook pro and am going through my paper logbook and I've found a few grey areas that I would like clarification on. The logbook I have doesn't have columns for solo or SIC time (just dual and PIC) so I've never had to log these before.
1. For the solo column is this for just when I'm a student pilot or whenever I'm the sole pilot in the plane (whether or not I have a passenger).
2. Say I split costs with another pilot. We fly 3 hours and 1.5 of that I am acting PIC even though I'm in the left seat the whole time. This is 1.5 PIC and 1.5 SIC correct? Dual received is only when I'm with a CFI that is logging dual given?
3. Throughout my instrument training my instructor logged both PIC and dual for me. But, there were about 5 flights before that I went up with an instructor to get re checked out in the flight schools planes since I was off for about a year after I got my PPL. They logged only dual and not PIC. I can log PIC for this since I'm rated and was acting PIC while the CFI just observed my flying?
Sorry for the basic questions but I don't want to mislog these things.:dunno:
71. For the solo column is this for just when I'm a student pilot or whenever I'm the sole pilot in the plane (whether or not I have a passenger).
  1. Solo applies to anytime that you are the only person in the aircraft. If you had a non-pilot aboard, it is still not considered "solo.
    Also, not just when you're a student doing your required solo flights.
  2. SIC can only be logged if you're flying an aircraft that requires 2 (or more) crewmembers (Boeing 737, for example). If you're flying a Cessna 172, for example, you won't be able to log that other 1.5 (in your example). You'll have to talk to your friend and see how you all want to split that. Yes, dual recieved is only if you're with a certificated CFI, they log dual given, and they sign your logbook.
  3. You probably could not log those flights as PIC because of the fact that you were not "current". The reg's state that to carry passengers, you must have your required landings (3 t/o's & ldngs within preceding 90 days). If you do not have those, you cannot act as PIC of that flight with passengers. If you were solo, you would log solo & PIC.
I hope that makes sense and helps!
In addition to student solo, the requirements for a commercial pilot certificate include a certain amount of solo time. So you can continue to use the solo column to keep track of those hours. If you look at 61.51 you'll see that, at least in theory, you're required to log the time as solo if you are, but that's probably violated more than it's obeyed.
I really have no idea what you asked. I'm not sure what "We fly 3 hours and 1.5 of that I am acting PIC even though I'm in the left seat the whole time." Are you saying that you and your pilot friend split the hands-on flying time?
If so, with one exception (we'll leave CFIs out of it) a pilot may only log the flight time when flying the airplane. To partially disagree with Michael, the exceptions occur when the "aircraft that requires 2 (or more) crewmembers" or the operation requires 2 crewmwmbers. In the Part 91 world, the latter only happens when one pilot is under the hood.
If that wasn't your question, try again.
Onthis one, I didn't understand Michael's answer, so let's start over.
Yes, you can log PIC but No, not because you were acting as PIC. You weren't. These were airplane that you were not authorized by the flight school to act as PIC in - that's why you were being checked out. You could log PIC in those aircraft because you're rated and were thr sole manipulator of the controls. See 61.51(e).
In fact, see 61.51, the universal rule for logging time, for the answer to every single time logging question you can come up with. 61.51 may send you somewhere else for certain things, but that the reg where every answer begins and most end.
If it helps, check my FAQ on logging time. It will point you to the source of the answers.
http://www.midlifeflight.com/faq/faq.php?s=1
Sorry I asked that question in a really funky way. I believe you got what I asked though. A friend and I would split the hands on flight time, thus giving us both PIC time. In my example, that would entitle me to 1.5 PIC and 3 for the total duration of the flight?
Negative, You can only log 1.5 PIC as well as 1.5 for total flight time. You can not log any time when you are a passenger.
Ah ok it's all clear now thanks guys. But now I'm wondering what's the point of splitting time with other pilots to time build if you only get half the time.:dunno: Looks like when I do some time sharing I'll have to go under the hood so both of us can at least log the time I'm under.
Dont forget, neither one of you can log the cross country time for those flight if one did the takeoff and the other did the landing.
It is worth it if one pilot agrees to be the "acting" PIC, while the other pilot is under the hood "logging" PIC under the sole manipulator clause. Two pilots both getting PIC time.
Example
You and a freind rent an airplane and fly it from airport A-Airport B-airport A with airport B being 51nm from airport A. Each leg takes you 1.5. On the way out you fly under the hood on the way back he flies under the hood, each agree before the flight to be the "acting" PIC while the other flies under the hood. Heres how it would be logged:
You
1.5 cross country
2.8 total time (you cant log the time the other pilot is taxiing, taking off or landing with the hood off)
2.8 PIC
Other pilot
1.5 Cross country
2.8 total time
2.8 PIC
Example
You
1.5 cross country
2.8 PIC
Other pilot
1.5 Cross country
2.8 total time
2.8 PIC
Yeah that's what I'm going to have to do. I know someone who is about to start instrument training and since he only needs 15 hours of instruction from a CFII (I think that's right it's off the top of my head) I volunteered to be a safety pilot for him so we can both build our time at a cheaper cost.
Another dumb question. I just want to make sure I'm not making any errors. :dunno: My flight legs should always be the same as the number of landings right? Say I fly sea-pdx-sea but go missed at pdx and don't land that would only count as 1 leg? Or if I fly 6 times in the pattern at bfi it would be logged as 6 different legs?
You can log them however you want. Just make it consistent.
I log them as flights. If you fly sea-pdx-sea and do a touch and go or just get out for a bit for lunch then fly back, I would log it as sea-pdx-sea, 2 landings. Logging every leg when doing touch and goes in the pattern is not needed and would just be a bunch of extra work for yourself. Just log the time and number of landings.
Yeah if I logged each leg individual back to my student pilot days it would take forever and be a mess to print out.:D I've always done it the way you described. Where I wanted to make sure i got it right was if I did, for example, a touch and go, then flew somewhere and back. I'll just log it BFI-PDX-BFI with 3 legs if I did a loop in the pattern before I left and make my life simple instead of printing out 500 pages with redundant flights. Thanks!
