91 flying and 135 rest.
I know that commercial 91 flying counts towards your flight time limits, but what I cant find is if you take a commercial 91 flight for a different company, does that screw up your 135 rest?
I almost positive the answer is no, but our POI isnt budging, so i need something in writing.
I've tried looking for a LOI, but they all pertain to flight times. Our POI is saying that if you take any commercial flight, even for a different company, then that cant be counted as rest for 135.
IE: My 135 duty day ends at 1600, and I pick up a contract flight that evening, which ends at 0200. POI is saying I'm not legal to go back on 135 duty until 1200.
You guys have any thoughts?
This may be what you are looking for.
Your second question asks if this same flight crewmember may
participate in the activities previously listed during a rest period if
the work was done for another company, not ABC,and whether the flight
crewmember could then accept an assignment with ABC for flight
operations under Part 135, at the end of the rest period.
The answer is a qualified yes. ABC, as the certificate holder, has no
way of forcing the flight crewmember to rest during a rest period.
The prohibition against "other commercial flying" during a rest period
applies to flying assigned by the certificate holder. The other
commercial flying done by the flight crewmember does count against
the daily 8 hour limitation if it is done before the Part 135 flying,
and also counts against the pilot's quarterly and yearly flight time
limitations. For example, 2 hours of "freelance" flight instruction
by the pilot during his rest period limits him to only 6 hours of Part
135 flying time during that 24 consecutive hour period. Any other
commercial flying done after the Part 135 flying does not count
against the daily limitation, but still counts against quarterly and
yearly totals.
An additional caution is that it is a violation of FAR 91.13 for a
certificate holder or a flight crewmember to operate an aircraft in a
careless or reckless manner so as to endanger the life or property of
another. Lack of rest of the pilot is certainly a circumstance which
could endanger others, and it is not necessary that the situation
devolve into actual endangerment for there to be a violation of FAR
91.13. A certificate holder who uses a crewmember with knowledge of
his or her lack of rest may be equally culpable along with the flight
crewmember.
LOI Link
Basically you can work for another company while on rest, but it isn't smart and puts both you and the 135 certificate holder at risk.
Speak for yourself, chum.
Hence the quotes, pal.
Maurus posted the right info. The FAA doesn't care what you do during your rest. That includes flying part 91 for someone else. As long as that commercial flight time is tracked for flight time limitations.
LOI Link
Isn't the first time and won't be the last that I'm wrong about something...
:D
