PanJet
good argument for always carrying a handheld comm first of all, eh?i'd say that if you missed on the first attempt due to not meeting the landing requirements, you'd miss again. proceed to your filed alternate..the weather is forecast to be better than your destination. atc will be protecting the airspace around you and note that you're routing there via appropriate airways/gps or direct the navaid if within the usable service volume. select the appropriate approach at your alternate, fly it and land. this is a rare occurrence, fortunately, but still no emergency. i wouldn't go below minimums. short of being able to land at the alternate as well (highly improbable), you're required to know the direction to nearest vfr weather. that's why you'll be carrying additional fuel to go beyond your alternate. get to vfr conditions, land and cancel.
Okay, I agree with what you're saying, but if I had no power except what's in the battery, and I'm not carrying some sort of backup (handheld radio and/or GPS, which I'm a big proponent of), would you chance not even having electrical power to navigate to your alternate? If you lose battery power you're done unless you're extremely good at situational awareness and timing. I don't know about you, but I'd take my chances on going past DA on the ILS. At least you're in somewhat of an approach setup where even if you don't taxi away from the landing you'll most likely walk away from it. You lose electrical and navs in solid IMC, God knows what you're going to hit.
