lightspeed
Nose wheel was the last to touch pavement = PASS
The vertical stabilizer is flexing on final...that's a ride.
When I did my JAA commercial pilot's license in the UK, my instructor told me "Whatever you do, don't do a forward slip to landing. I did that and I got roasted by the examiner." Anyways, on my flight test, I did the wing low method on a crosswind and the examiner brought it up in the debrief and said that I need to start doing the crab and kick method ...I'm sure you can, it's just that every video that guy has put out shows every aircraft landing in a crab no matter what it is, so I tend to think of it as a technique employed over there in the training pipeline.
It looks like the spoilers start to deploy before the 2nd/final touchdown. Is that bad?
If you really bounce and the boards come out, you could potentially damage the aircraft when it turns into a brick.
One of the 767 guys can speak to spoiler logic, but all spoilerd airplanes have it. If certain criteria is met, the spoilers deploy. They touched down the first time, whatever it was, they met it so even though they bounced the airplane threw them out anyway. On the RJ the only way they will stow (initially) is with thrust lever advancement. If you don't then no matter what the plane does, the boards are coming out. Same thing happened here. To answer your question about being bad...no and maybe. If you bounce a little, then you will get a form second touchdown as seen in the video. If you really bounce and the boards come out, you could potentially damage the aircraft when it turns into a brick.
In the 767, if they're armed, it's truck tilt angle combined with the thrust levers at idle. It appears that they didn't deploy during the first touchdown (probably still had thrust in), but only the flight spoilers came out during the bounce. It looks to me like someone in the cockpit manually moved the lever to "up."
Just a guess.
Here is a 767 landing which resulted in a write off. Landing on the nosewheel is bad, mmmkay. Unless its the An-124, but you know, Russia.They all look GREAT to me, whats that old saying " a good landing is one you can walk away from and a great landing is one where you can use the aircraft again"
