300nm x/c
amd87
I'm planning to do my 300nm solo x/c for the commercial requirement this Wednesday. I first planned to fly CZG-PWM-GFL-CZG with CZG-PWM being ~270nm to fulfill the 250nm straight-line distance requirement. Having that said, is it acceptable for me to take a stop inbetween the CZG-PWM leg for a break/fuel/food? I can't find anything in the FARs that says specifically that a LEG must me >250nm from the first departure point, but I have heard it phrased as if a single leg must be >250nm from the first departure point.
As long as PWM is still 270mi away, is it okay if I stop halfway inbetween on the way for a total of 4 landings?
Thanks!
Thanks!
NO, the leg wouldn't be 270 miles if you stop.
So the 250nm requirement must be completed in a single leg? The entire trip can't just include an airport that is >250nm? Since it says at least 3 different landings, I assumed that I could make 10 landings on this trip if I wanted to, as long as one of them was at least 250nm away from the first departure airport.
There is nothing that says an individual LEG must be 250nm; you can do it in as many segments as you need, but one of your stops needs to be at least 250nm from where you started. To wit:
§ 61.129 (a)(4)(i): One cross-country flight of not less than 300 nautical miles total distance, with landings at a minimum of three points, one of which is a straight-line distance of at least 250 nautical miles from the original departure point.
It doesn't all need to be the same day, either; I did my solo XC from San Diego to Lake Tahoe a few years ago, made one stop for fuel each way, for a total of four legs, and Lake Tahoe is more than 250nm from San Diego, so it's legit. The bonus is that at the time, I wasn't aware of the solo XC requirement for the commercial ticket. Serendipity!
As aloft indicates, you are fine. There needs to be a landing at at least one point that is 250 NM away from where you started, but there is no requirement for any 250 NM leg.
