C150J
121.471 (a) No certificate holder conducting domestic operations may schedule any flight crewmember and no flight crewmember may accept an assignment for flight time in scheduled air transportation or in other commercial flying if that crewmember's total flight time in all commercial flying will exceed--
(1) 1,000 hours in any calendar year;
(2) 100 hours in any calendar month;
(3) 30 hours in any 7 consecutive days;
(4) 8 hours between required rest periods.
From the ALPA flight time limtations book.
Q-3. A flight crewmember has flown 30 hours in a six-day period. On the sixth day, can the carrier assign the crewmember to fly a ferry flight following the completion of the revenue flying that will cause the crewmember to exceed 30 hours of flying within a seven-day period?
A-3. Yes. Ferry flights are normally conducted under Part 91, and the flight-time limitations are applicable only to Parts 121 and 135. Some carriers do apply Parts 121 and 135 to ferry and repositioning flights. If you are unsure as to whether it is Part 91 flying, you should make appropriate inquiries. However, ferry flight time under Part 91 must be counted as “other commercial flying” to determine compliance with the monthly and yearly flight-time limits. Moreover, if the ferry flight time is accumulated before attaining 30 hours of flight, then it must be counted in determining the 30-hour limitation.
How is a Part 91 maintenance flight NOT considered "other commercial flying" for 30-in-7, but "commercial flying" for every other limitation? Doesn't this fly in the face of "one level of safety?" Just because you have no passengers on board, it certainly doesn't change the fact that you're flying above and below planes full of passengers.
J.
J.
