2 part question...
JJPilot
Well, I have good and bad news first the good, I have finally after 6 weeks or so, lined up my first job in the aviation industry flying right seat. Now, here is where the problems start.
1. I have just found out that they are going to a 135 op and I am not certified. I know that it entails a checkride but frankly am at a loss as to where to begin. Any sugestions? This is something that was supposed to be a ways down the road for me so I have not looked into it at all. Any suggestions would be appreciated!
2. And much less dire, I am looking for some info on aircraft. I know that they are flying centerline thrust Cessna's (337's) I believe. Any other twins by cessna of this configuration?
Wish me luck!
JJPilot
pilot602
1) If you are SIC on a 135 op you may not need the checkride. If you do you'll need roughly 1,200TT and 500 XC (I believe) along with a few other requirements. Ask the company, they should be getting you ready for the ride - at the very least they should be getting you in contact with the right people so as to do the ride.
2) The 336 is the other centerline from Cessna. The 36 is a fixed gear (first version) and the 37 is an RG.
xdashdriver
The short answer is that you will have to undergo Initial training and do a checkride with the FAA / Company check airman. There are no minimum time requirements for SIC under Part 135. The long asnwer is below :-
§ 135.245 Second in command qualifications.
(a) Except as provided in paragraph (b), no certificate holder may use any person, nor may any person serve, as second in command of an aircraft unless that person holds at least a commercial pilot certificate with appropriate category and class ratings and an instrument rating. For flight under IFR, that person must meet the recent instrument experience requirements of part 61 of this chapter.
§ 135.293 Initial and recurrent pilot testing requirements.
(a) No certificate holder may use a pilot, nor may any person serve as a pilot, unless, since the beginning of the 12th calendar month before that service, that pilot has passed a written or oral test, given by the Administrator or an authorized check pilot, on that pilot's knowledge in the following areas --
(1) The appropriate provisions of parts 61, 91, and 135 of this chapter and the operations specifications and the manual of the certificate holder;
(2) For each type of aircraft to be flown by the pilot, the aircraft powerplant, major components and systems, major appliances, performance and operating limitations, standard and emergency operating procedures, and the contents of the approved Aircraft Flight Manual or equivalent, as applicable;
(3) For each type of aircraft to be flown by the pilot, the method of determining compliance with weight and balance limitations for takeoff, landing and en route operations;
(4) Navigation and use of air navigation aids appropriate to the operation or pilot authorization, including, when applicable, instrument approach facilities and procedures;
(5) Air traffic control procedures, including IFR procedures when applicable;
(6) Meteorology in general, including the principles of frontal systems, icing, fog, thunderstorms, and windshear, and, if appropriate for the operation of the certificate holder, high altitude weather;
(7) Procedures for --
(i) Recognizing and avoiding severe weather situations;
(ii) Escaping from severe weather situations, in case of inadvertent encounters, including low-altitude windshear (except that rotorcraft pilots are not required to be tested on escaping from low-altitude windshear); and
(iii) Operating in or near thunderstorms (including best penetrating altitudes), turbulent air (including clear air turbulence), icing, hail, and other potentially hazardous meteorological conditions; and
(8) New equipment, procedures, or techniques, as appropriate.
(b) No certificate holder may use a pilot, nor may any person serve as a pilot, in any aircraft unless, since the beginning of the 12th calendar month before that service, that pilot has passed a competency check given by the Administrator or an authorized check pilot in that class of aircraft, if single-engine airplane other than turbojet, or that type of aircraft, if helicopter, multiengine airplane, or turbojet airplane, to determine the pilot's competence in practical skills and techniques in that aircraft or class of aircraft. The extent of the competency check shall be determined by the Administrator or authorized check pilot conducting the competency check. The competency check may include any of the maneuvers and procedures currently required for the original issuance of the particular pilot certificate required for the operations authorized and appropriate to the category, class and type of aircraft involved. For the purposes of this paragraph, type, as to an airplane, means any one of a group of airplanes determined by the Administrator to have a similar means of propulsion, the same manufacturer, and no significantly different handling or flight characteristics. For the purposes of this paragraph, type, as to a helicopter, means a basic make and model.
(c) The instrument proficiency check required by § 135.297 may be substituted for the competency check required by this section for the type of aircraft used in the check.
(d) For the purpose of this part, competent performance of a procedure or maneuver by a person to be used as a pilot requires that the pilot be the obvious master of the aircraft, with the successful outcome of the maneuver never in doubt.
(e) The Administrator or authorized check pilot certifies the competency of each pilot who passes the knowledge or flight check in the certificate holder's pilot records.
(f) Portions of a required competency check may be given in an aircraft simulator or other appropriate training device, if approved by the Administrator.
Buzo
Those are IFR PIC mins. Like Raysalmon said, there are no mins for SIC other than a commercial, instrument.
