0 0 takeoff
ComplexHiAv8r
Has anyone ever done a 0 0 takeoff? While not part of my checkride yesterday (not graded), he had me do it (with foggles) since it is legal Part 91. Very strange feeling.
Not sure I would ever want to do that. Don't need to get there that bad.
I've done a few in the sim and a couple under the hood. They are scarry as hell! There's no friggin way I'll ever do one in actual 0 0 conditions.
Did a 200 - 1/2 Take Off once from Martha's Vinyard...
Funny, my gear warning went off as I put up the gear (172RG, found out later the switch that tells the warning system when the flaps are 20 degrees or greater got stuck) so I recycled the gear down as I entered the clouds...
The tower got sort of concerned seeing my gear come down then I dissapear in the clouds and asked if I had a problem and would I like to come back in...
I was thinking... "Hmmm, try to land in 200 - 1/2 weather or go the whole way with my gear down, I think I'll go back to Schenectady NY and their 2000 - 10 SM" (BTW the Vno and Vge is the same for a 172 RG).
But as I reached the tops I put the gear back up and the warning didn't sound...
I have done a few 00 takeoffs with the foggles and like you it sucked and couldnt imagine doing it with fog that thick. Then again I drove around south Orlando with a muck fire burning and I could barely see over the hood of the car....
How do you keep from going off the runway before rotation? I assume you can at least see 20 feet or so right?
Just gotta keep the heading indicator from moving and hope for the best. And yes, it is crazy.
In reality though, if you can see well enough be able to taxi onto the runway, you can probably see at least one centerline stripe in front of you, but in a true 0 0 takeoff you aren't supposed to be able to. Especially if you do them with foggles, there's no seeing 20 feet through the foggles.
That's why having a LOC helps. Not that I would even attempt this in actual conditions, though.....
Anyone here ever done a 0 0 landing before. I've done 1 with a CFI, and I think my examiner tried to have me do it on my IA checkride but I screwed it up. It's freaky as hell.
If the examiner tried to have you do one, he was probably trying to see if you'd go missed at the appropriate time. I'm sure you know that unless you, the aircraft, and the approach are properly certified, you cannot legally descend below MDA/DA if the conditions are below minimums for the approach i.e. 0 0.
Nope, I called "minimums" and he said to keep on bringing it down. Certainly something you wouldn't do by yourself
Huh,...
Tell me you passed the checkride, or at least didn't bust because of that.
It was legal because the examiner was in the right seat. He was probably trying to impart knowledge and give him some experience in case he ever did have to land 0-0 in an emergency situation.
I remember my instructor having me do a few 0/0 takeoffs under the hood when I was training for my instrument. It must be something a lot of them do just for the heck of it. He didn't seem to make out like it was a formal part of training, just doing it to see what I thought and how I'd do.
Huh,...
Yeah, I know it was legal, but surely not within the limits of the PTS. If he'd have busted for that we'd have to get MikeD involved.
He was probably bored and wanted to have a little fun
My instructor is like 72 with 27,000 hrs. and he told me about a time where he landed in practically 0 0 he said it was crazy, he was low on fuel at his alternate he finally saw the runway when he started his flare and then all he could see was the sides. He has me do 0 0 take offs with foggles on so many times that their not even a big thing anymore.
