When to change altimeter
adams
To best explain my question I'll give a scenario. I take off from YZX airport with the ATIS altimeter setting. I get handed off to SoCal which gives me another altimeter setting that I am to use. I get vectored around a little and I am cleared for the approach to XYZ airport. At what time do I change the altimeter setting that Socal gave me, to the one at the local airport. I would say when you are cleared for the approach as well as some other people. But I would like to know if there is a written procedure on this topic.
Again, when do you change the altimeter setting from the one the approach controllers give you, to the one at the airport. Thanks.
I've never seen a recommended procedure for this. I change it to local as soon as I receive it; so far, this hasn't caused a problem with ATC, although I could imagine circumstances in which it would.
:yeahthat:
I change it when one of three things happens:
1. ATC gives you the local airport altimeter
2. When you receive the ATIS/AWOS/ASOS
3. ATC asks you if you have the wx at XYZ
Usually on a flight, some of these blend together. The best thing to do is that if you are within a good range of the airport and have the altimeter setting, just set it there and use it. The AIM says you should update your altimeter setting every 100nm. So if you are within that distance and have the altimeter setting, you should be fine. I have not seen/or heard a problem with this. Of course, I'm not very experienced as much as fellow JC'ers on here.
Change it every 100 NM on a cross country at the minimum if not talking to ATC. If talking to ATC change it whenever you hear it on the radio.
You know this very same question was going through my head just yesterday. I looked through the FAR/AIM today and couldn't find anything specific.
Basically what I have been doing is setting to whatever ATC says, if they tell me to get ATIS for my destination then I will switch to that one.
I have yet to receive settings that were more than a few tenths different so I never really considered it a big deal, but I bet it could be if conditions were right.
It could, but "big deal" situations tend to involve traffic density where being on altitude avoids potential conflicts or IMC where a bad altimeter setting can be a really bad day.
And there can be big differences within a pretty small area, especially in mountainous areas. In those cases, altitude aside, the differences can tell you certain things about wind and weather.
