To tell somebody, in the soup, to simply turn to a heading without any lateral guidance is a great way to find yourself smack dab in the side of a mountain.
You're way over-analyzing this, IMO. TERPS approved procedures are full of dead-reckoning segments in which arcing would be a bizarre thing to do. While it's a good idea to use DME info to see if your intercept is working, attempting to maintain a particular DME distance until the course is intercepted is an arbitrary thing to do; you don't know that the terrain is clear along this course any more than you do on a direct intercept.
Nope, but doing what you just described is a great way to run into something.
I'd certainly do an arc to it. It's the most straightforward way to do what the examiner wants while maintaining your situational awareness.
I dunno about you, but I have this thing about always having positive identification of where I'm at. Call me crazy, but as soon as the CDI goes full deflection, I have no idea where I'm at (unless you have a GPS with a moving map, which still isn't good enough in the FAA's eyes for knowing your exact position). So you arc over to it, and track it inbound.
To tell somebody, in the soup, to simply turn to a heading without any lateral guidance is a great way to find yourself smack dab in the side of a mountain. In a Cessna 172 flying /A you have no idea what the winds are, what kind of correction you need to put in, and most importantly what's between you and this mythical point in space out there that you're recommending dead reckoning to.
That's just me, though, and how I would perform the maneuver. I honestly believe to teach anything else is to invite the student to think that this is a safe course of action, and perform this maneuver you're describing in the soup with terrain around them. That's a recipe for disaster, in my opinion.
You don't simply go blasting out into space without course guidance
So you're saying that arcing gives you terrain clearance?!
Sorry, but that's a totally misguided argument to support the notion that arcing to get to another radial is somehow better/safer than turning direct to another radial.
If you're making an argument about SA, then how about you mention if you're below MSA? Or how about ESA? Or maybe even the min vectoring altitude of whatever agency you're with?
Besides...this guy was on a private checkride...he was interested in if the guy knew if the radial was on his left or on his right. He wasn't asked to perform a HSI-only fix-to-fix, cut the arc, arc, or anything remotely like that.
Just left turn or right turn. Simple question.
So what are you going to tell ATC the next time they give you radar vectors to the final approach course? I suspect, by using your logic you will decline the vector and fly the full approach.
What about an MSA or Grid MORA? Are we permitted to accomplish such unsafe action even above these altitudes?
Also, I can make a turn to intercept the radial...crossfix my position along the way...without having to do a DME arc.
What if the arc takes you outside of protected airspace? How do you know the course along the arc won't take you closer to terrain than a heading to intercept?
You are giving bad advice and setting the applicant up for failure by trying to establish himself on an arc between closely spaced radials.
To state that the only safe way to accomplish this maneuver is via a DME ARC is a bunch of crap.
I don't know how many times I depart JFK towards an easerly fix and the controller simply states intercept the "123 radial to xyz fix".
This conversation went to hell real quick..
jtrain609 said:In my mind, this is one of those instrument flying fundamentals. You don't simply go blasting out into space without course guidance, and I could care less about what the examiner says about whether it's a good idea or not. I think it's a horrible one, and I know a handful of examiners that would bust an applicant on the spot for going somewhere without course guidance.
jtrain609 said:GPS navigation sure has screwed up the way we think about instrument flying.
Point being, as soon as you go full deflection on your CDI while casting off into space without terrain clearance from the TERPS (so, assuming you're not on an approach procedure) sounds like a horrible idea to me.
That is so dangerous!If you are so concerned with positive location why not just spin the OBS so you no longer have full deflection? A centered needle and DME will show you exactly where you are. Follow along on your handy dandy sectional, keeping an eye on terrain depicted, and we're happy as clams!
Still a private pilot (additional rating) checkflight though.Whoops, I re-read the post. It was an instrument ride. You're right. Disregard my words on that subject.
Either way, doesn't change the facts of the discussion.
Terrain clearance is a function of an MSA, not of being on or off a radial or arc.
Has everybody missed that the guy asked the student to do a DME arc with incredibly non standard phrasing?
That's all the student had to do.
While I agree that the phraseology was non-standard, the feds are a little weird when it comes to this stuff. I had an inspector tell me that an advanced rating applicant needs to be able to understand and properly respond to a non-standard command from ATC during an investigation of some of the students I signed off.
I was always under the impression that the PTS rules all, but the real answer is "kinda".
