bdhill1979
Gone West
:yeahthat: If you can't see the valleys and clearings, you're screwed.Night flight in mountains is crazy regardless of whether it's VFR or IFR.
I call myself an alive Utard.Call yourself a Utahan. You should be ashamed Napoleon!
Having all of the flights in my logbook originating or terminating in this state, I WILL NOT attempt to cross the mountains in the dark unless I can see lights below me (following the highway for example).
Would you attempt to cross the Uintahs from Kamas to Flaming Gorge in a single at night? If so I have on e question for you:
Have you ever heard of nylon polymer?
What?! Are you joking? Any night flying I do is over the peaks of the Blue Ridge Mountains, with primarily no lights.Having all of the flights in my logbook originating or terminating in this state, I WILL NOT attempt to cross the mountains in the dark unless I can see lights below me (following the highway for example).
That's why the FAA has requirements for either an SIC or an autopilot for Part 135.
Just get your peak heights and keep an eye on the steam. You can be a man and still be safe!
wikipedia said:The Blue Ridge is composed of many fragments scarcely connected into a continuous and regular chain. Its higher summits range from 5000 to nearly 6,700 feet, however, its average elevation is from 3000 to 4,000 feet
I am talking about real mountains.
The kind you need oxygen to legally cross.
The kind that stretch on unbroken for miles and miles and miles.
It has nothing to do with altitude, but having absolutely no options if you have a power loss. There have been several fatalities around here from just that happening when people were flying over mountains at night.
Depends. But I'd say single-pilot IFR is one of the more hazardous operations out there. That's why the FAA has requirements for either an SIC or an autopilot for Part 135. But if you're out there Part 91--pick your poison!
Here you go Steve...
Originally Posted by Doug Taylor April 13, 2007
Maybe I'm weird but non-commercial single-pilot IFR is nuts, single-pilot single-engine IFR is even crazier. So what's the point of the glass?
You're more likely to die in a car crash than dying because your only engine hit the john..It has nothing to do with altitude, but having absolutely no options if you have a power loss. There have been several fatalities around here from just that happening when people were flying over mountains at night.
What the h3LL does being "a man" have to do with it?You can be a man and still be safe!
I don't know about you, but I take the car risk every day.
