DUI
Find out what the requirements are to get the DUI conviction expunged (post conviction relief), if that is even an option in your area. I recommend you contact a qualified DUI expungement lawyer in your city as well.
This is your next step.
I am not sure of this though, but I believe you can get it expunged from your state records and such so on a basic background check this will not show up. It takes a few years (normlaly like 5), but eventually this can be done.
The caution area! On an FBI fingerprint background check, I believe this will always show up. Most expunged records will still show up at this level of background check. Pretty much, only police departments, airlines, school districts, etc. do this level of check. A normal employer/ company would never find out about it since they do not do fingerprint FBI checks.
Rule of thumb: Pretty much, once on the FBI record, always on the FBI record. So you will always need to answer you been guilty of a DUI in my opinion. You can expunge your local records, seal them, etc. But 9 of 10 times you will not get anything removed from your FBI / fingerprint background file.
PS - Given your circumstances, I am pretty confused on why you did not hire an expensive attorney who would have been able to plead this first offense down to reckless driving and improperly registered vehicle. Then after serving some probation time having the case dismissed. Or worse case, a good attorney would have been able to get this reduced to reckless driving and then continued without a finding or first offender so there still would have been no guilty verdict.
Anyway, I would still pursue your dreams. No one is perfect. Everyone makes mistakes. It's how we learn and become better people from the mistakes. And trust me, I made my share of mistakes too!
There may be a few holdouts, and there are always exceptions, but I'm pretty sure that in most states, the reduction of a DUI to a non-DUI offense is a thing of the distant past.
That said, I am also surprised by what appeared to be the OP's decision to walk into court and plead guilty without being represented by, or at least consulting with, a lawyer. There may well have been alternative available, such as a deferred disposition, which would make a difference in certain circumstances. Is it still true that you cannot fly in Canada if you ever had a DUI ? – there's a good reason for not hiring someone as a pilot.
omajeta, a couple of things...
I didn't see this mentioned, but have you reported the DUI (as well as the initial administrative license suspension if there was one) to the FAA within 60 days after it occurred as required by FAR 61.15? And don't forget to report it on your next medical application as well.
Folks have talked about such things as expungement, etc. It might not be possible, and, even if the procedure exists in your state, it usually tends to require a wait of a number of years. But if you did not have a lawyer before, find a good one now. There may not be a lot that you can do, but you should get some advice from someone in your state who actually knows what he or she is talking about and takes responsibility for the advice you get.
Even a deferral =now= is not out of the question. If the picture I've been getting is that you said "guilty" at your very first court appearance and this was a forum where deferred dispositions (which are called different things in different places) was an option, the judge and the prosecutor may have been shaking their heads that you didn't even give them a chance to give you a break. A good lawyer =might= even at this point, prevail upon a sympathetic judge to reopen the case to change the disposition. A long shot, but it's probably worth a couple of bucks to find out.
Thanks all for the input. I might of been and probably was a little naive to the whole process. I guess that is why I should of hired an attorney. I am not sure though if that would of helped out or not. When I was doing community service as well as attending DUI classes I spoke to those who had hired an attorney and pretty much ended up in the same spot with the same conviction.
In NE right away your license is suspended for 90days on the spot and if you refuse the breath test then they will take it for a year! I guess I was just in the position of not wanting to play around with the courts and just do what the judge wanted me to do and get it over with. Granted that really messes up my good record, but at the same time it is done and over with and I am moving on!
Lessons learned, too many to count.
Yepper, I reported that a week after I went to court. That was within the time frame. I am glad that I did do a search and find out that I had to make the report.
Thanks!
Word of advice to anyone who gets in a similar situation...never, ever blow. If you blow over the limit you are done. Guilty as charged. If you refuse to blow you can get a lawyer and get the charge dropped or reduced to reckless driving. Just don't blow, especially if you passed the field sobriety test.
There are issues with not blowing as well.
First, you might be able to get by with a reduced charge, but in a lot of states, the refusal to blow is admitted as evidence at the DUI trial (yeah, I know that you can beat a DUI even with refusal to blow being presented to a jury - been there, done that, but it's a =very= long shot).
Second, in some states the refusal to blow is an offense. Where it is it probably involves a suspension of driving privileges which, while not a DUI, it's still reportable to the FAA under 61.15 and on a medical certificate application. Might not have all of the consequences of a DUI but it's hardly a pass.
Third, even if the refusal to take a breath test is not an offense, it might be grounds for on-the-spot license suspension. Again, not as many consequences as a DUI conviction, but still reportable to the FAA under 61.15.
So DUIs and DUI-related stops always have consequences for pilots and there is no universal rule I can think of that fits everybody in every community, in every situation.
Good for you. One less thing to worry about. The FAA rarely does anything to a pilot based on a single DUI offense. Although, if they do, please consult a lawyer. Might be worth you while to join the AOPA legal services plan.
If you don't want to blow fine. Just don't expect the cop to put on the police report that you passed the field sobriety test, even if you did with flying colors. Cops are looking to gather evidence against you during the stop to get a solid conviction. When you deny them of the most powerful type (BAC level) they aren't pleased. They will do everything in their power to make you look like the most drunk person in the city that night. Remember the prosecution goes on what the cop puts in the police report as if it was GOD's truth. Lies, exaggerations or not.
If you plan on not blowing do yourself a favor and shut your mouth, don't answer any questions. DO NOT take a field sobriety and be polite. Reduce the amount of "evidence" against you.
FST's make me laugh. They expect you to do something that is abnormal, cops have no clue how each individual would perform under the best circumstances and doing these tests have no real bearing on ones ability to operate a motor vehicle. On top of that a cop has no "special" expertise in identifying if someone is drunk, he/she is an average citizen. If FST's are such great ways to measure ones ability to drive then they would be required at the DMV to perform these test before you get your drivers license.
Or - how about, don't drink and drive?
It was funny - Ian and I were out at a bar a few weeks ago and a guy was talking on the phone to his girlfriend, asking her if she was okay to drive. "Are you okay enough to not get pulled over?" he said.
Which seemed an interesting concern, but maybe that was because I'd just visited a presentation given by two mothers whose kids (17 years old) had died on the same night in separate incidents of drunk driving.
One of them killed a guy in another car, and the other slammed so hard into an oncoming car their vehicles rose up into the air, and his car exploded. His three friends died, too.
I think getting pulled over is probably the least of the worries...
That is best lesson learned to not drink and drive, but as simple as that sounds it is very difficult to follow unless you have a plan in place before hand. Good decision making after a couple beers is not the time to be making decisions!
Kind of like pressing on into marginal weather, everyone has heard how bad it is and how it kills pilots, but many people die from it every year! (anyone ever scud run before?) That is something that I would of never done in an airplane! But by pre-planning and being of sound mind you can minimize the chance that you would be presented with that situation. And if you are then you have a plan in place and an alternate airport to go to to eliminate the risk.
The scary part of this is how many people on this board or friends that you know have driven over the limit, and just not been caught?
This was not my first time, it was my first time getting caught. (saying that does not mean that I am a drunk, it just makes me honest!) Will it be my last time, without a doubt.
And did I mention that I had a CDL (commercial drivers license) too? Yeah, that is gone...:banghead:
A few companies in Alaska actually like some tainted people because they believe they will stick with that company.
-because they cannot go anywhere else.
I am posting this because the replies have been way too leanient. I have zero respect for drunk drivers & I will never fly with you as a crewmember omajeta. Im not being harsh, this is reality. Make a slight misjudgement like this in aviation and you can kill lots of people in mere seconds.
^^ I think thats taking it a little to far man, everyone makes mistakes, he just made a little bigger mistake than others.. i mean I'm sure there are people in the aviation business that are flying commercially that have done alot worse lol...
I believe he was asking for advice regarding his situation, not for an opinion regarding his actions, which he has already confessed as being irresponsible.
I would stay in insurance if I was you. A DUI is a huge red flag for 121 carriers. Since you got one recently it will be nearly impossible for you to be hired in the near future. I would guess you'll need a clean record for a least 5 years before they'll consider you.
it might have been possible when everyone was dying for pilots but I agree with Marcus, stay in insurance.
You will be able to advance in this industry, but it will take a little bit for time to put in between the DUI and an interview to fly commercially.
While it seems that it's the end of the road, I know for a fact that it's not a career stopper. I had a roommate who got a DUI with resisiting arrest when we were flying at a regional. He pled guilty, did the classes w/ probation. THey dropped the resisting charge and expunged the DUI when he took the classes and finished probation. He subsequently got hired by a Legacy carrier and flys a 767. He was straight up with them and the lecture we got from the head of FltOps for the Legacy (we were roommates with his son,) was:
Keep your nose clean. Everyone makes mistakes so be honest. Tell them what you learned from it and don't ever do it again. Once, is a stupid mistake. Twice, is a habit.
Good luck and keep looking forward.
Hate to ruin your crusade but it won't say "obajeta" on your crew pairing.
Careful about making absolute statements. Can you honestly say that you have never made any errors in judgement? Some are more serious than others, but in the end we all need to remember, "But for the Grace of God, go I."
I know of a cat that got popped when he graduated college, got on at a commuter, and now flies a jet with engines on the tail for a legacy.
They exist.
Oh, then there's a cat outta Yipsilanti that hires some REAL characters.
The candor and remorse shown by the OP will take him far.
Peace....back to my homelife.
You can be an alcoholic, get a DUI bust, and become President of the United States. The people that will blatantly stand in your way are in the minority, especially if you're genuinely sorry for a past mistake.
you never sped in your life?
I can show u some pictures of ppl that look pretty bad from speeding... (where I couldn't even post them here without getting banned, just as bad as drinking/driving pics of ppl)
so I should never fly with u if you sped?
misjudgment...
drinking, driving is bad, speeding is bad, rolling through a stop sign is bad. but its important that sometimes we get caught before making a deadly mistake... and you learn from it.
