Who cares?![]()
Very important because lots of training departments don't teach this stuff. There is both a high- and a low-speed buffet margin that can really "ruin your day" if you don't have an understanding of where they are.
coffin corner!!! Not to be confused with the "turn your head and coffin corner" which is an unfortunate day in the doctor's office.
Did you guys know there was a coffin corner for helicopters too?
Isn't that what they call a helicopter cockpit.Did you guys know there was a coffin corner for helicopters too?
Pretty interesting poll. The answer is the plane will stall at a higher IAS, for two reasons
-compressibility effects on the airspeed; the ASI will read higher than it should
-airflow separation due to shockwave effects at a high TAS
Maybe that is just the basic they teach for the PPL though.
It's actually Mach number dependent, rather than altitude dependent. For piston airplanes, the Mach number is so low, you really won't see the effect, so it's appropriate to teach students the constancy of IAS for performance-related airspeeds.
In the Mach .2-.3 range you actually may see a stall speed reduction, because the increase in Reynolds number has a stronger effect than Mach number.
Shoot - felt like I was in a coffin jammed in the back of your Lear fearing for my life because I saw you intentionally flew through clouds WITHOUT an autopilot on.Isn't that what they call a helicopter cockpit.
yak yak yak
:bandit:
Sorry for the rough ride honey.Shoot - felt like I was in a coffin jammed in the back of your Lear fearing for my life because I saw you intentionally flew through clouds WITHOUT an autopilot on.
