skyhigh600
Sec. 91.117 - Aircraft speed.
(a) Unless otherwise authorized by the Administrator, no person may operate an aircraft below 10,000 feet MSL at an indicated airspeed of more than 250 knots (288 m.p.h.).
(b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class C or Class D airspace area at an indicated airspeed of more than 200 knots (230 mph.). This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section.
(c) No person may operate an aircraft in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots (230 mph). (d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed.
Two questions
(1) Realizing that ATC is not the administrator/faa, when can or would 250kts below 10,000 ft ever be authorized (in US airspace for this argument)? How would it be authorized? I've been told that Houston Tracon has been waiving this speed limit for years now...do they have an LOA or something of the sort from the FAA?
(2) I have been told specifically by an FAA inspector (when asked) :bandit:that ATC can waive the 250kt speed limit below 10,000 ft when in class B airspace. I didn't buy it, and when I pointed to the language in the regs for 91.117(a), "...by the administrator..." he said that ATC was "...delegated authority..." [FAR 1] by the FAA, and thus could waive it in their airspace?
Referring to AIM 4-4-12(h):
Pilots are reminded that they are responsible for rejecting the application of speed adjustment by ATC if, in their opinion, it will cause them to exceed the maximum indicated airspeed prescribed by 14 CFR 91.117(a),(c), and (d).
Note the absence of reference to 91.117(b) where the language is "...unless otherwise authorized or required by ATC...".
Wrapping this all up...is there some specific reg that trumps all the above saying ATC can wavie 250kts under 10,000 ft that I am missing here???
anic:
Thanks!!
Two questions
Thanks!!
