MidlifeFlyer
True, but it's not usually the best idea to put evidence of an FAR violation in your logbook which is what the context of this discussion suggests.An IFR clearance is not necessarily required to log actual IFR.
-mini
-mini
So you were in the clouds for .2 hours? Or did you maintain VFR cloud clearance at all times?
I'm not sure that you can find an example in the AIM, other that the many examples of being "cleared" "IFR." The transition from VFR to IFR, even just for a climb or descent, is still a pop-up IFR clearance and you would know whether you got it or not. (Remember, you are the one who "can't say" whether your were given an ifr clearance or not.)Nice slippery slope. . .not. I won't go into the semantics of right/wrong, so help me, please. 'Source' the exact words of IFR climb in the FAR/AIM to perform an "IFR climb" when I'm on VFR traffic advisories. I need the insight.
MFT1Air said:Yep, it was a climb in addition to the haze caused by the government initiated fires in the area. Add to the it was dark, there's my .2
I sure didn't. I am saying that there is areg violation if you're operating an airplane in "meteorological conditions less than those required for VFR flight" ("IMC") in controlled airspace when not on an IFR flight plan.Who said it's a regulation violation if you're logging actual without an IFR clearance?
LOL. I love how I asked the question as directly as possible and you can't seem to answer is succinctly without clouding (pun fully intended) what happened.
My advise: don't log any actual for this flight. (It's only .2, what's the big deal anyway?) It sounds like either you were not in IMC or your flight into IMC was a violation of FARs. Secondly, please review FAR 91.155 (VFR cloud clearance and visibility requirements) prior to your next flight.
Are you instrument rated?
another side lesson to be learned here:
"UNABLE"
remember, ATC cannot force you to bust a reg, so put that word UNABLE to good use!
So, you're saying if flight into IMC was accidental, I show make an erroneous input into logbook?
OK, I need more insight into your comment; elaborate please?
It doesn't sound like he was assigned a higher altitude, but rather requested it while receiving VFR advisories.
in flying, you will encounter a time (or many times) when ATC will direct you to do something that is
a) unsafe
b) illegal
c) foolish
d) all of the above
such as directing a VFR pilot to make a climb into the clouds where he or she has no place going because it is (d) all of the above
in this case the proper reaction of the PIC would be "hey, i cant do that!... sorry atc, cessna 123 UNABLE"
another case that happened at my school recently, the tower asked a landing aircraft to turn off at a taxiway before the plane had slowed enough to do so safely... well... the pilot thought ATC was "the law" so he tried to make the turn, ended up taking out a runway entrance sign and going in the ditch.
you as the pilot IN COMMAND have to make the right judgement call, and for a variety of reasons, what ATC advises may not be the right thing to do!
hope that explains my post.
Let's go with that thought. Remember that you may violate an FAR in case of emergency. But there are two "gotchas." One is that you may only violate to the extent required to meet the emergency. The second is that you cannot have contributed to the emergency. That's a heavier burden than you might think.Also, thoroughly read 91.155. No violations were applicable to me at the time I initially got my weather briefing. Additionally, that low overcast/haze rolled in unexpectedly given the fires that were being initiated in the area.
