L-39 Driver
My apologies to the forum.
I just found the multi-quote link - could have used that in the past.
She is good looking. I remember servicing the Duke, back when I worked at an FBO at Oakland North Field many years ago. It was the hottest looking thing on the ramp, including all of the jets at that time, IMO. That's how much I enjoyed just looking at it back then.
Funny how life sometimes leads you full circle. If you check out the specifications in that link that was given, you will see that they claim a 1,000ft T/O distance to clear a 50ft obstacle! I have not checked the STOL requirements lately, but that has got to be pretty close!
I'm seeing Duke B60's ranging from $170k up to $300K+. So, depending on the conversion/modification costs of the PT6, it might even turn out to be more cost effective than a new 90 (for sure), a used Cessna 425 or a used King Air x90x. I'll be calling them on Thursday to get some details - I'll follow-up here later, of course.
I don't know much about that airframe at all - but 100 psi does not read like much. How does that translate into a loss of 15%/15%?
Gee, if 100 psi = 15% reduction in power and the loss rate in linear, then a mere 300 psi reduction would equal a whopping 45%% power reduction - that's almost HALF! How?
...Then I saw the ROYAL TURBINE DUKE!! Sickest(good) looking airplane I've ever seen!!! Get the Duke, assuming she fits your mission profile.
I had a nice long answer to this typed up and then I loss my internet connection and poof it went. Ice vanes are used to keep contaminants (water, ice, dirt, and etc...)from getting into the compressor stages of the powerplant. Located just aft of the intake scoopes...when deployed a small door opens, which due to inertia, causes a small amount of air and contaminants to exit out the rear. Since some of the air that would normally go to the compressor exits with the contaminants, you'll lose maybe 100 psi torque. Not a lot in the grand scheme of things.
