maybe thats why there isnt a VDP depicted on all approach plates... The TERPSters cant guarantee obstacle clearance in the descent from MDA unless youre visual to see and avoid. Just a guess.
8260.3 United States Standard for Terminal Instrument Procedures (TERPS)
253. VISUAL DESCENT POINT (VDP) (applicable to straight-in procedures only). When dual minimums are published, use the lowest minimum descent altitude (MDA) to calculate the VDP distance. PUBLISH A VDP FOR ALL STRAIGHT-IN NONPRECISION APPROACHES except as follows:
• Do not publish a VDP associated with an MDA based on
part-time or full time remote altimeter settings.
• Do not publish a
VDP located prior to a stepdown fix.
• If the
VDP is between the MAP and the runway, do not publish a VDP.
a. For runways served by a VGSI, using the VGSI TCH, establish the distance from THR to a point where the lowest published VGSI glidepath angle reaches an altitude equal to the MDA. Use the following formula:
VDP Distance = [MDA - (TCH + THR Elevation)]/Tan(VGSI Angle)
b. For runways NOT served by a VGSI, using an appropriate TCH from table 18A, establish the distance from THR to a point where the greater of a 3° or the final segment descent angle reaches the MDA. Use the following formula:
VDP Distance = [MDA - (TCH + THR Elevation)]/Tan(*Angle)
c. Marking VDP Location.
(1) For Non-RNAV SIAP’s, mark the VDP location with a DME fix. The DME must be collocated with the facility providing final approach course guidance (USN/USA/USAF NA).
If DME is not available, do not establish a VDP. Maximum fix error is ± 0.5 NM.
(2) For RNAV SIAP’s, mark the VDP location with an along track distance (ATD) fix to the MAP. Maximum fix error is ± 0.5 NM.
(3) If the final course is not aligned with the runway centerline, use the THR as a vertex, swing an arc of a radius equal to the VDP distance across the final approach course (see figure 14-12). The point of intersection is the VDP. (For RNAV procedures, the distance from the point of intersection to the MAP is the ATD for the VDP.)
And here is the issue that seagull mentioned:
b. Obstacle Clearance. Two obstacle identification surfaces (OIS) overlie the visual area with slopes of 20:1 and 34:1, respectively. When evaluating a runway for circling, apply the 20:1 surface. When evaluating a runway for an approach procedure satisfying straight-in alignment criteria, apply the 20:1 and 34:1 surfaces. Calculate the surface height above threshold at any distance “d” from an extension of the area origin line using the following formulae:
20:1 Surface Height = d/20
34:1 Surface Height = d/34
(1) If the 34:1 surface is penetrated, take ONE of the following actions:
(a) Adjust the obstacle height below the surface or remove the penetrating obstacles.
(b) Limit minimum visibility to ¾ mile.
(2) In addition to the 34:1 evaluation,
if the straight-in runway's 20:1 surface is penetrated, take ONE of the following actions:
(b)
Do not publish a VDP, limit minimum visibility to 1 mile, and take action to have the penetrating obstacles marked and lighted.
(c)
Do not publish a VDP, limit minimum visibility to 1 mile, and publish a note denying the approach (both straight-in and circling) to the affected runway at night.
(3) If the 20:1 surface is penetrated on circling runways, mark and light the penetrating obstacles or publish a note denying night circling to the affected runway.
