Start of the workday
Pietrantonio
Here I am again with yet some more questions. :)
I've been studying my IR material, and I just finished up the wx section. More specifically types of wx reports such as METARS, TAF, FA, etc...
So, it's the start of the workday and you arrive. What is the process you go through before you start the engines, to taxi and depart to your destination(s)? What are your most frequent types of wx checks? How do you file flight plans? Who determines if flights are cancelled? Who goes to pre-flight? etc...
This is something that I've never had any insight on, and I've been curious as to how it works.
Again, as always, I appreciate your time answering the questions.:)
Where I'm at now, a lot of this stuff is already taken care of and all we need to do is check the data on the flight plan and the weather.
Starting a trip, we'll roll up to the airport an hour before the first flight is supposed to leave. I'll go to the weather room to meet the captain/grab the release. Our release has our flight plan on it, all the fuel burn stuff, the weather and all the NOTAMs we'll need. Everything is already filed and we just need to take a look at it.
As an FO, I'll grab the data I need for the TOLD card, look to see if we have an alternate, look at the weather/NOTAMs for our departure, destination and alternate, and underline things I think are important. Personally? I'm looking for NOTAMs that we need to know about, current/forecasted weather at our departure airport, destination and alternate and making sure that our alternate is legal, etc. etc. By this point the captain has usually shown up, we'll shake hands and I'll hand the paperwork to him/her. They'll do the same, look at whatever captains look at, and we'll be on our way.
FO's do the preflight while the captain generally jumps in the plane and gets everything powered up and ready to go. I'll jump back in the plane, get my nest setup and start running flows or grabbing the weather or whatever else presents itself. Depending on the configuration of the aircraft (whether have one or two FMS') kind of determines what I'll do first.
Pretty much the same stuff you do on any flight.
I'll give you an overview of how I started my day flying single pilot freight.
Typically, I'd get my complete weather briefing via DUAT at home while having my first cup of the evening's coffee. I would get a standard briefing, and pay particular attention to METARs, TAFS, FDs, NOTAMS and PIREPs. I'd also take a look at the Surface Analysis Chart, Lifted Index, Icing Level Chart, Doppler Summary and the 12-hour Surface Prog Chart. By using these products, I was usually able to build a pretty good picture of the weather outside. With lots of practice and experience, you can usually do all of this in just 5 or 8 minutes, and that's when the weather is crummy. On a good day, I could knock this out in 2 minutes or less. before I left the house, I'd also check Flightaware to see if my flight plan was showing in the system. if not, I'd just file a new one real quick.
Soon after, I'd drive to the airport and show up at the hangar 30-45 minutes before my departure time, and call Ops to check in. The first order of business is to preflight the aircraft. By doing this, I had time to have MX fix any minor problems I found. This wasn't an option when I had the first departure of the day in Nashville (0530 showtime), so I'd just pick a new aircraft and do it through Ops.
In the winter, at this point, I'd jump in the airplane, start it up and taxi over to the other side of the ramp and warm it up for 5 or 6 minutes, then do a good, thorough run-up. In the baron, I'd also run the heater for a while and get the airplane nice and warm while I sipped on my coffee. While it was warming up, I'd also get the ATIS and then just before I taxied back to the front of the hangar, I'd pick up my clearance (always as filed). If the wx dictated a route change, I'd request it at this time.
So, taxi back to the ramp, use the head, and proceed to load the cargo. Get my W&B done, and take one more peek at the METARS and (if applicable), TAFs and radar.
That was it! If my couriers were on time or better and I had no mechanicals, I get get out 10 minutes early every day!
