Accident to a Boeing 777-236, G-YMMM, on 17 January 2008 at 1243 hrs
Initial Report Update 23 January 2008
Since the issue of the Air Accidents Investigation Branch
(AAIB) 1st Preliminary Report on Friday 18th January 2008
at 1700 hrs, work has continued on all fronts to identify why
neither engine responded to throttle lever inputs during the
final approach. The 150 tonne aircraft was moved from the
threshold of Runway 27L to an airport apron on Sunday
evening, allowing the airport to return to normal operations.
The AAIB, sensitive to the needs of the industry including
Boeing, Rolls Royce, British Airways and other Boeing 777
operators and crews, is issuing this update to provide such
further factual information as is now available.
As previously reported, whilst the aircraft was stabilised
on an ILS approach with the autopilot engaged, the
autothrust system commanded an increase in thrust
from both engines. The engines both initially responded
but after about 3 seconds the thrust of the right engine reduced.
Some eight seconds later the thrust reduced on the left
engine to a similar level. The engines did not shut down
and both engines continued to produce thrust at an engine
speed above flight idle, but less than the commanded thrust.
Recorded data indicates that an adequate fuel quantity was
on board the aircraft and that the autothrottle and engine
control commands were performing as expected prior to, and
after, the reduction in thrust.
All possible scenarios that could explain the thrust
reduction and continued lack of response of the engines to
throttle lever inputs are being examined, in close
cooperation with Boeing, Rolls Royce and British Airways.
This work includes a detailed analysis and examination of
the complete fuel flow path from the aircraft tanks to the
engine fuel nozzles.
Further factual information will be released as and when
available.
The AAIB will continue to release all information on the
progress of their investigation.
