You can get as much or as little mutli engine time from as FBO as you please. That is the beauty of going to an FBO. If you just want your commercial multi, MEI, and the 15 hours of PIC to instruct in a ME, then you only need about 25-30 hours of multi engine. Personally, I recommend getting the 25-30 hours of ME time, and then flight instructing to get the rest. There are plenty of opportunities out there.
Lets make a quick budget to show you how easy it is to ONLY spend $35k on flight training. To make things simple, lets just look at airplane and instructor costs. Add in books, supplies, and examiner costs is maybe $2k-$3k on top.
- Fly a 1980 era Cessna 172. If you want to save several thousand dollars, you could do it in a 152.
- Lets use the rate of $90 an hour for a Cessna 172. That is between middle of the road to high end for a 1980 C172.
- Lets use the rate of $40 an hour for instructor time
- Lets use the rate of $210 an hour for a multi. Again, this is between middle of the road to high end for a multi. I paid much less than both these rates!
To get private through commercial SE:
250 hours of C172 flight time
Lets say 90 hours of flight instruction time (40 private, 40 instrument, 10 commercial, again, generous estimates).
Lets use 45 hours of ground instruction.
So: 250*90 = $22,500
135*40 = $5,400
Now lets say 10 hours SE for a CFI, and 25 hours ME for commercial multi and CFII/MEI. Say 35 hours flight instruction and 20 hours ground instruction. Again, generous time estimates.
10*90= $900
25*210= $5,250
55*40= $2,200
Total cost for 285 hours (NO SAFETY PILOT TIME), 25 ME, 190 hours (plenty of instructor time) and Private through MEI (for middle of the road to high cost airplanes/instructors) =
$36,250
Now lets say you use my rates ($65/hr SE, $200/hr ME, and $35/hr flight instructor), you get a total cost of
$28,550!. Add in examiner fees, medical, books, supplies, IFR jepps, and it comes out to 30-35K.
If you want 100 hours of multi, using the high rates you get:
$44,350. You DO NOT need 100 hours of multi engine time from flight training. But if you don't want to MEI, and you plan on going to Skywest or Republic...fine. Using my lower rates, total cost (with 100 hours multi AND NO SAFETY PILOT TIME) = $38,025!!
To see a comparison using FBO prices versus ATP, check out this post:
http://forums.jetcareers.com/airlin...attending-atp-please-advise-2.html#post748809
This compares the cost of doing ATP's ACCP to doing the same exact training/flight time at a local FBO, and the results are just incredible.
If you decide against buying your own airplane (could be cheaper, but may be tougher), then definately go to a lcoal FBO. The cost savings are incredible. And you can finish it AS FAST OR FASTER than ATP on your own schedule.
