mhcasey
Max gross weight: I've heard two theories. One states that Vmc is lowered at max gross weight because the heavier aircraft has more inertia, therefore requiring greater asymmetrical thrust to accomplish the same yaw rate.
The other theory is that Vmc is increased at max gross because chances are the aircraft is going to yaw at least a little bit before you input rudder control, and this heavier aircraft will therefore have greater momentum and will require more rudder to bring the nose back around.
In regards to the latter: All else equal, even if we accept theory two, it seems that the momentum shouldn't be an issue. The same asymmetrical thrust/drag (force) is acting on both aircraft, so the lighter aircraft will just yaw faster and have the same momentum.
This is a quote from my D.E.'s website: "A multiengine airplane experiences a sudden failure of the critical engine while in flight. The airplane begins to yaw to the left, regardless of its mass. The surprised pilot then applies right rudder in order to stop the yawing motion, stabilize the airplane around its vertical axis and then maintain a constant heading. A heavier airplane will require more rudder effectiveness to accomplish this. At some point, the rudder may reach full deflection and Vma will be reached. This will occur at a higher airspeed for a heavier airplane."
Anyone want to shed some light on this issue? Does the higher angle of attack required at max gross for any given airspeed have any effect on Vmc?
Here's another one regarding banking into the inoperative engine:
"Holding a bank in the direction of the operating engine may increase the performance of the multiengine in some respects, but it definitely raises Vmca...The pilot of this airplane has banked five degrees in the direction of the operating engine in an attempt to maintain coordinated flight. In order to maintain that bank, the aileron controls must be held in a bank to the right...The result is that drag is increased on the left and decreased on the right, increasing the yawing moment to the left. The asymmetrical drag increases the rotational force vector and raises Vmca."
Essentially he's saying that banking into the operative engine increases Vmc because of adverse yaw. I can't help but wonder if this is actually the case in an engine out scenario? It seems like a component of the aircraft's weight may be vectored opposite the asymmetrical thrust/drag, therefore reducing the yawing moment? If this is the case, the max gross lowering Vmc would hold more merit also. Your thoughts?
