New news... If your headset is not tso'd, do not use it with a fed on board, they have orders to crack down and have the discression to violate. From my FSDO friend...
My director of flight standards does, I called the other guy to confirm.
ESF, I'm just passing along what I have heard first hand. Not trying to start anything.
TSO Headsets
Pilots are reminded that only TSO certified headsets are authorized for use by the FAA in Delta aircraft. A TSO - or Technical Standards Order - is a document the FAA uses to qualify a component attesting it has certain performance, capabilities, or standards. A vendor who qualifies a component to a TSO avoids a portion of certification expense as well identifies it meets FAA criteria specified in the TSO itself.
All components, as a function of TSO compliance, must identify TSO compliance on a permanent label. If a headset does not identify the TSO, it most likely does not comply. Owners need to contact the manufacturer to be certain.
Harder do hear our chimes without the ANR. The FAA is just running out of things to violate people for that's all.
Whenever I fly into Mexico is sounds like they're talking into tin cans attached to strings that are run up to the airplane.
