Berkut
Yep.Cessnaflyer said:So max continuous at altitude is more then max allowed for takeoff?
You can download the TCDS here: http://rgl.faa.gov/Regulatory_and_G...79578854D89E712286257209007693D4?OpenDocument
Scroll down to the PA-34-200T (Seneca II) engine limits, and it says:
In a Seneca II, the same RPM/MAP setting gets you 200HP at sea level, but 215HP at 12,000 feet.Engine Limits
For all operations, 2575 r.p.m. and 40" Hg. Manifold pressure, 200 hp @ S.L. and 215 hp @ 12,000 ft.
So does the Seneca II require a high-performance endorsement?
An even better question is, why the heck does the Seneca II put out more power at 12,000 feet than it does at sea level with the exact same RPM/MP settings? Answer that one and you'll win... well, nothing, but I'll be impressed.
