Murdoughnut
Well sized member
I found it especially helpful during the first 20 hours - could practice flying a pattern and making radio calls to yourself. Also good for practicing engine outs.
ASA, a leading marketer of aviation training aids, has a book called "Microsft Flight Simulator As A Training Aid". It's an excellent read for you if you're thinking about incorporating MSFS into your studies. I'd suggest you get with a CFI that is comfortable with this technology, and has a bit more than a month or two as a CFI. I've found, surprisingly, that a lot of the very senior CFI's (20+ years on the stick) are quite open to the idea of using MSFS as a learning tool.
Ask the U.S. Navy how much it doesn't help . . . and that was years ago.
It's very easy to say, "It's a game . . . gahhhh . . . there's no value", because that's the cool thing to say (Note above "I've heard it helps a bit with IFR training, but that's it!"). It's not always easy to stray away from the popuylar crowd.
Well, not sure about you and the author of this thread. But when I see people playing MSFS they aren't flying a 172.
Well, now you're qualifying the original statement, and in doing so, it's making more sense. However, I've seen CFI's in airplanes giving ineffective training. That doesn't mean "CFI's don't help students learn to fly".
I've known lots of people that fly the 172 on Flight Sim. I know I still do!
It's normally something made by Boeing or Airbus and maybe Embrarer or Bombardier.
In which it won't help you learn to fly at all, lest you start your PPL training in one of those aircraft!
Even the payware stuff is a great thing to mess around on.
Even the payware stuff is a great thing to mess around on. Heck, my good friends’ dad is a DAL captain, and he was blown away by how the PMDG 737 FMC was identical to his FMC in his (real) MD-88. He gave us a quick overview and sure enough my buddy and I are cranking away at the FMC loading flight plans, calculating weight and balance, and getting our V speeds. In fact, I recently had the opportunity to sit in a full motion Level D 737 simulator. I was aloud, and able to load a flight plan and calculate everything I needed that was pertaining to the flight. So now tell me FS 2004 is worthless haha.![]()
When I was 15 we didn't have MSFS. I don't think we even had computers...
Well, then if that's the case then I should seriously consider putting in an app at Air Tran. Because last year when I flew that 717 level D sim raw data, and the sim instructor called me a natural stick, and had to double and triple check that all the automation was off. I guess that means that I could easily jump into a 717 or similar and pilot it from the right seat ATL to MDW no problem!
Right, right?![]()
I've never played with the Feel There ERJ-145, so I can't tell you how much it helps somebody understand what's going on. . .![]()
Now what you do need to do Max is get on with your real flight training!![]()
ORLY NOW!!!
YA RLY!! Sounds like you're a good pilot. GIT-R-DONE!
I'm good enough to be dangerous!!!
You can be my wingman anytime
LOL. ICEMAN!
