Okay let's try this again.
ALTIMETER SETTING DOES NOT EQUAL PRESSURE OUTSIDE OF THE AIRPLANE.
Altimeter setting is adjusted based on field elevation.
29,92" Hg = A29.92 only at sea level (given standard temperatures. Non standard temps at other altitudes would also permit this).
For example, as a rule of thumb, you lose an inch of mercury every 1000 feet.
In Denver, when they get the barometric pressure, it might actually be something along the lines of 24.92. Via a magic formula, they recalculate it and you'll get a local altimeter setting.
So where does this all come in to play? Let's take that 143MB and subtract it from standard pressure (1013.2 MB). We are doing this because this airport is 143MB higher than sea level. Through the magic of science, we're able to determine that 870.2MB is roughly equivalent to 4150 feet.
Does that correspond with the airport elevation (fairly closely)? If not, I messed up. If so, I did well
