taildragger173
Ok, so I remember learning this a few years ago but I'm drawing a blank now. Why is that some approaches have a final approach fix and others do not? What is the criteria for not having a final approach fix?
Mainly it happens on a non precision approach when the navaid is located on the field.
your discription fits what is probably the majority on-airport NDB and VOR approaches - you start down after the PT precisely because there is no FAF to start the descent at.
If there is DME associated with the primary navaid for the approach there is (almost) always be an FAF. I think the only time there isn't one is when there would be no way to identify one.Does DME play a role in this?
Right, but that happens with on-airport navaids, not off-airport navaids. Compare that EGT one I just posted with this one at 2K3 - the NDB is pretty close - only 2.7 miles from the runway but it's still used as an FAF.Exactly what I was referring to.
