Which speed keeps ATC happy?
Center_Mid
Over the weekend, I was flying my club's 172 on the 13R ILS into Boeing Field in Seattle. I'm about four miles from the outer marker and the controller asks me what max speed I could maintain for spacing. I look at my airspeed and power configuration and quickly estimate that I could maintain 120 KIAS. So, I respond with 120. However, as the approach continues, I notice my groundspeed on the GPS is showing around 110-113 knots. No matter what I did power-wise, I would get 120-125 indicated but never more than 113 over the ground.
I had a Caravan, a Lear, and another 172 behind me on the ILS. I heard ATC slow the Caravan down for me and I would guess the Lear had to slow, too. I felt a little bad about clogging the pipeline, especially since it was just a practice ILS in VFR conditions.
My question is: next time, should I estimate what groundspeed I could maintain or stick with indicated?
The controller works with ground speed. But...remember that all those airplanes behind you on approach are experiencing the same headwind you are. If you are told to maintain 120 KIAS and the wind is holding you at 113 ground speed, then the Lear behind you is doing 160 KIAS and 153 across the ground. Seven knots is seven knots. Stick to indicated.
ATC will always talk to pilots with regard to indicated speed, not groud speed. Same with headings versus ground track. Fly the headings and indicated speeds that they give you and let them worry about correction for the winds. They're (usually) pretty good at it.
I used to go to Bremerton a lot for the ILS rather than mix it up at BFI. You really wanna get some attention. Try holding at NOLLA at 2000 feet...just to exercise your right to be there. You're outside the B and outside BFI's D, just barely...
Hehe, that'd be a good way to get to know everyone up close 'n personal.
Sort of. You pay a membership fee and get a discount off the retail hourly rate. That's about it. It's not a "club" in the social sense.
Same thing as when I used to rent from there.
Do they provide any lube for you when you pay for their aircraft? ;)
